Ana içeriğe geç
VTech Learning Tunes Karaoke Speaker Replacement
Neye ihtiyacın var
  1. VTech Learning Tunes Karaoke Speaker  Replacement, Speaker: adım 1, 1 resimden 1.
    • To remove the battery door, loosen the screw using a Flathead screwdriver.
    • A coin can also be used to loosen the screw.
  2. VTech Learning Tunes Karaoke Speaker  Replacement: adım 2, 2 resimden 1. VTech Learning Tunes Karaoke Speaker  Replacement: adım 2, 2 resimden 2.
    • Remove the battery door and take out the batteries.
  3. VTech Learning Tunes Karaoke Speaker  Replacement: adım 3, 1 resimden 1.
    • Remove the six 9.5 mm Phillips #2 screws.
    • Remove the six 6.0 mm Phillips #2 screws.
  4. VTech Learning Tunes Karaoke Speaker  Replacement: adım 4, 2 resimden 1. VTech Learning Tunes Karaoke Speaker  Replacement: adım 4, 2 resimden 2.
    • Gently pull up on the rear panel.
    • Be careful to not pull on the wire connections.
    • Carefully place the back panel underneath the top panel with the tops facing each other, as shown in the picture.
  5. VTech Learning Tunes Karaoke Speaker  Replacement: adım 5, 2 resimden 1. VTech Learning Tunes Karaoke Speaker  Replacement: adım 5, 2 resimden 2.
    • Remove two 7.9 mm Phillips #1 screws on the speaker cover.
    • After removing the screws, remove the black plastic speaker cover to expose the speaker.
  6. VTech Learning Tunes Karaoke Speaker  Replacement: adım 6, 1 resimden 1.
    • Desolder the speaker at the solder points to remove.
    • Learn more about soldering and desoldering connections here.
Sonuç
Gamuchirai Chifamba
249 İtibar
2 adet Kılavuz yazıldı
Ekip
USF Tampa, Team 7-2, Cheng Spring 2016 USF Tampa, Team 7-2, Cheng Spring 2016 üyesi
USFT-CHENG-S16S7G2
4 Üyeler
10 adet Kılavuz yazıldı
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 0
Son 30 gün: 8
Her zaman: 708
