Ana içeriğe geç
VTech Learning Tunes Karaoke Volume Switch Replacement
Neye ihtiyacın var
  1. VTech Learning Tunes Karaoke Volume Switch Replacement, Volume Switch: adım 1, 1 resimden 1.
    • To remove the battery door, loosen the screw using a Flathead screwdriver.
    • A coin can also be used to loosen the screw.
  2. VTech Learning Tunes Karaoke Volume Switch Replacement: adım 2, 2 resimden 1. VTech Learning Tunes Karaoke Volume Switch Replacement: adım 2, 2 resimden 2.
    • Remove the battery door and take out the batteries.
  3. VTech Learning Tunes Karaoke Volume Switch Replacement: adım 3, 1 resimden 1.
    • Remove the six 9.5 mm Phillips #2 screws.
    • Remove the six 6.0 mm Phillips #2 screws.
  4. VTech Learning Tunes Karaoke Volume Switch Replacement: adım 4, 2 resimden 1. VTech Learning Tunes Karaoke Volume Switch Replacement: adım 4, 2 resimden 2.
    • Gently pull up on the rear panel.
    • Be careful to not pull on the wire connections.
    • Gently place the back panel underneath the top panel with the tops facing each other, as shown in the picture.
  5. VTech Learning Tunes Karaoke Volume Switch Replacement: adım 5, 2 resimden 1. VTech Learning Tunes Karaoke Volume Switch Replacement: adım 5, 2 resimden 2.
    • Using a Phillips PH1 screwdriver, remove the two 7.9 mm volume switch board screws.
  6. VTech Learning Tunes Karaoke Volume Switch Replacement: adım 6, 1 resimden 1.
    • Once the screws have been removed, carefully move the volume switch board.
  7. VTech Learning Tunes Karaoke Volume Switch Replacement: adım 7, 1 resimden 1.
Sonuç
Lezette Leuterio
101 İtibar
1 Kılavuz yazıldı
Ekip
USF Tampa, Team 7-2, Cheng Spring 2016 USF Tampa, Team 7-2, Cheng Spring 2016 üyesi
USFT-CHENG-S16S7G2
4 Üyeler
10 adet Kılavuz yazıldı
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 0
Son 30 gün: 7
Her zaman: 263
