Giriş
If you notice that the power is on but no sound will come through your device, this could mean that the speaker needs to be replaced. make sure you are careful while taking the device apart to avoid damaging the wires and soldered pieces.
For more information regarding soldering visit: Soldering Skills
Neye ihtiyacın var
Expose the battery compartment by removing the lower back cover of the device.
Do this by holding the back side of the device upside down in your hands and applying pressure to the indented portion with both thumbs.
Use the Philips #0 Screwdriver to remove the two 11.2 mm screws located on either side of the battery slots.
Bir başkası bu kılavuzu tamamladı.
