Ana içeriğe geç
VTech Spin and Learn Color Flashlight Speaker Replacement
Neye ihtiyacın var
  1. VTech Spin and Learn Color Flashlight Speaker Replacement, Battery Housing: adım 1, 2 resimden 1. VTech Spin and Learn Color Flashlight Speaker Replacement, Battery Housing: adım 1, 2 resimden 2.
    • Locate the battery housing on the back of the flashlight as pictured.
    • Unscrew the single 8 mm Phillips #1 screw.
    • The screw will stay attached to the cover that will be removed.
    • Lift the battery housing cover to reveal the battery terminals. Remove the batteries.
  2. VTech Spin and Learn Color Flashlight Speaker Replacement, Speaker Housing: adım 2, 3 resimden 1. VTech Spin and Learn Color Flashlight Speaker Replacement, Speaker Housing: adım 2, 3 resimden 2. VTech Spin and Learn Color Flashlight Speaker Replacement, Speaker Housing: adım 2, 3 resimden 3.
    • Locate the light blue speaker housing on the bottom of the flashlight.
    • Remove the three 6 mm Phillips #0 screws.
    • Once the screws have been removed, pull the housing away from the yellow body of the flashlight. Be careful not to disconnect the white wires from the speaker, unless speaker replacement is required.
  3. VTech Spin and Learn Color Flashlight Speaker Replacement, Speaker: adım 3, 3 resimden 1. VTech Spin and Learn Color Flashlight Speaker Replacement, Speaker: adım 3, 3 resimden 2. VTech Spin and Learn Color Flashlight Speaker Replacement, Speaker: adım 3, 3 resimden 3.
    • Locate the wires connected to the speaker indicated by the red circles in image one.
    • Desolder the wires from the connection point circled in the second image. If you're unsure of how to use the soldering station, use iFixit's guide to soldering and desoldering to help.
    • Remove the 2 highlighted 4mm Phillips #0 screws in image three.
Sonuç
Nathaniel Troyer
441 İtibar
4 adet Kılavuz yazıldı
Ekip
USF Tampa, Team 2-6, Blackwell Fall 2015 USF Tampa, Team 2-6, Blackwell Fall 2015 üyesi
USFT-BLACKWELL-F15S2G6
3 Üyeler
18 adet Kılavuz yazıldı
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 3
Son 30 gün: 10
Her zaman: 460
