Ana içeriğe geç
VTech VM3254 Monitor Circuit Board and Screen Replacement
Neye ihtiyacın var
  1. VTech VM3254 Monitor Circuit Board and Screen Replacement, Battery: adım 1, 2 resimden 1. VTech VM3254 Monitor Circuit Board and Screen Replacement, Battery: adım 1, 2 resimden 2.
    • Turn the monitor on its back, and remove the two 8 mm Phillips #0 case screws.
  2. VTech VM3254 Monitor Circuit Board and Screen Replacement: adım 2, 3 resimden 1. VTech VM3254 Monitor Circuit Board and Screen Replacement: adım 2, 3 resimden 2. VTech VM3254 Monitor Circuit Board and Screen Replacement: adım 2, 3 resimden 3.
    • Use the iFixit Jimmy tool to begin removing the face of the monitor.
    • You may need to use an opening pick to hold the screen open as you move the Jimmy tool around all the edges of the device.
    • Once the screen has been separated, lift it from the case.
    • Be gentle while removing the screen. There are wires connected to the two pieces that may be damaged.
  3. VTech VM3254 Monitor Circuit Board and Screen Replacement: adım 3, 2 resimden 1. VTech VM3254 Monitor Circuit Board and Screen Replacement: adım 3, 2 resimden 2.
    • Remove the four 8 mm Phillips #00 screws from the bracket that secures the battery.
    • Remove the bracket.
  4. VTech VM3254 Monitor Circuit Board and Screen Replacement: adım 4, 3 resimden 1. VTech VM3254 Monitor Circuit Board and Screen Replacement: adım 4, 3 resimden 2. VTech VM3254 Monitor Circuit Board and Screen Replacement: adım 4, 3 resimden 3.
    • Gently remove the battery from its location.
    • Carefully disconnect the bundled cable connector from the circuit board.
  5. VTech VM3254 Monitor Circuit Board and Screen Replacement, Monitor Speaker: adım 5, 2 resimden 1. VTech VM3254 Monitor Circuit Board and Screen Replacement, Monitor Speaker: adım 5, 2 resimden 2.
    • Remove the two 7 mm Phillips #00 screws from the speaker.
    • Carefully remove the speaker and its cords from the motherboard.
    • Handle gently to not break the motherboard or any other parts.
  6. VTech VM3254 Monitor Circuit Board and Screen Replacement: adım 6, 1 resimden 1.
    • Desolder the wire connecting the speaker to the board.
  7. VTech VM3254 Monitor Circuit Board and Screen Replacement, Monitor Circuit Board and Screen: adım 7, 2 resimden 1. VTech VM3254 Monitor Circuit Board and Screen Replacement, Monitor Circuit Board and Screen: adım 7, 2 resimden 2.
    • Remove the three 8 mm Phillips #00 screws.
    • Gently remove the screen and circuit board from the case.
  8. VTech VM3254 Monitor Circuit Board and Screen Replacement: adım 8, 2 resimden 1. VTech VM3254 Monitor Circuit Board and Screen Replacement: adım 8, 2 resimden 2.
    • Remove the button assembly from the front of the screen unit.
    • Flip the screen unit back over and desolder the wire holding it to the case.
Sonuç
Christina Block
375 İtibar
4 adet Kılavuz yazıldı
Ekip
1Rehber Yorum
Any source for replacement screens?
Rob Olivieri - Yanıt
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 2
Son 7 gün: 8
Son 30 gün: 53
Her zaman: 1,561
