Ana içeriğe geç
VTechCS6719-16 Speaker Replacement
Neye ihtiyacın var
  1. VTechCS6719-16 Speaker Replacement, Speaker: adım 1, 1 resimden 1.
    • Remove the sliding cover on the back of the phone case.
    FixBot'a Sor
    Yorum Ekle
  2. VTechCS6719-16 Speaker Replacement: adım 2, 1 resimden 1.
    • Now remove the battery by lifting it and removing the two pin cable.
    FixBot'a Sor
    Yorum Ekle
  3. VTechCS6719-16 Speaker Replacement: adım 3, 1 resimden 1.
    • Unscrew the two 10mm screws on the back of the phone base.
    FixBot'a Sor
    Yorum Ekle
  4. VTechCS6719-16 Speaker Replacement: adım 4, 1 resimden 1.
    • Using the metal spudger edge along the phone and locate the hooks and latches.
    • Locating each of them apply a light but firm lifting force to release the front and back case.
    FixBot'a Sor
    Yorum Ekle
  5. VTechCS6719-16 Speaker Replacement: adım 5, 1 resimden 1.
    • The front case should now be freed.
    • Put the front case aside for later.
    FixBot'a Sor
    Yorum Ekle
  6. VTechCS6719-16 Speaker Replacement: adım 6, 1 resimden 1.
    • There are two 10mm screws located at the top of the circuit board.
    • Unscrewing the screws allows for access to the speaker.
    FixBot'a Sor
    Yorum Ekle
  7. VTechCS6719-16 Speaker Replacement: adım 7, 1 resimden 1.
    • Flipping the circuit board will expose the speaker rested in the white LCD base.
    • Gently using the scoop end of the spudger will free the speaker from the dock.
    • Careful not to jerk the speaker as it is still attached to the board.
    FixBot'a Sor
    Yorum Ekle
  8. VTechCS6719-16 Speaker Replacement: adım 8, 1 resimden 1.
    • The last portion of this will require soldering skills. Simply solder the speaker from the board and replace with desired speaker.
    • If this is your first time soldering, check out this useful soldering guide.
    FixBot'a Sor
    Yorum Ekle
Sonuç
Charles montes
513 İtibar
5 adet Kılavuz yazıldı
Ekip
UMass Dartmouth, Team 5-5, Martin Fall 2016 UMass Dartmouth, Team 5-5, Martin Fall 2016 üyesi
UMASSD-MARTIN-F16S5G5
3 Üyeler
15 adet Kılavuz yazıldı
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 4
Son 30 gün: 24
Her zaman: 466
