Ana içeriğe geç
Valve Index Headset Head Strap Clip Replacement
Neye ihtiyacın var
  1. Valve Index Headset Head Strap Clip Replacement, Remove the head strap clip: adım 1, 3 resimden 1. Valve Index Headset Head Strap Clip Replacement, Remove the head strap clip: adım 1, 3 resimden 2. Valve Index Headset Head Strap Clip Replacement, Remove the head strap clip: adım 1, 3 resimden 3.
    • Insert the flat end of a spudger in between the bottom of the head strap clip and the head strap padding.
    • Pry up on the head strap clip until it is unclipped from the head strap.
    • To reinstall, first locate the recesses on the head strap for mounting the clip. Next, align the clip with the recesses, verify the tether cable is threaded through the clip, then simply press the clip back into place.
Sonuç
Repair didn’t go as planned? Try some basic troubleshooting, or ask our Valve Index Answers community for help.
3 farklı kişi bu kılavuzu tamamladı.
Sam Omiotek
85.261 İtibar
290 adet Kılavuz yazıldı
7Kılavuz Yorumları
Why are these clips so expensive? At $39.99 it's like someone mashed an extra 9 when putting in the price, the face gasket which is much larger, uses more material and is more robust costs less than half, even the power adapters are $5 cheaper.
Dor - Yanıt
Seems that the price has been corrected to $4.99
Dor -
Yeah. The price is seriously insane! Two smaller zipties fit through that opening just fine and cost me pennies and work better than that cheap plastic clip.
Joshua Dworsky - Yanıt
Maybe i might have a older verison of the index because the larger clip piece on the top doesnt even clip in
Brent - Yanıt
scratch that you need to put the SMALLER side in last which is was this post doesnt say :)
Brent - Yanıt
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 1
Son 7 gün: 21
Son 30 gün: 113
Her zaman: 8,660
