Ana içeriğe geç
Valve Index Headset Motherboard Replacement
Neye ihtiyacın var
  1. Valve Index Headset Motherboard Replacement, Remove the front cover: adım 1, 2 resimden 1. Valve Index Headset Motherboard Replacement, Remove the front cover: adım 1, 2 resimden 2.
    • Use your hand to pull the front cover straight off of the front of the headset.
    • The front cover is held in place by four magnets that secure to screws in the motherboard cover.
    • Before installing a front cover, ensure the four screws securing the motherboard cover are installed. Otherwise, the front cover will not stay in place.
  2. Valve Index Headset Motherboard Replacement, Remove the motherboard cover: adım 2, 1 resimden 1.
    • Use a T5 Torx screwdriver to remove the four 5.4 mm screws securing the motherboard cover to the headset.
  3. Valve Index Headset Motherboard Replacement: adım 3, 2 resimden 1. Valve Index Headset Motherboard Replacement: adım 3, 2 resimden 2.
    • Remove the motherboard cover from the headset.
  4. Valve Index Headset Motherboard Replacement, Remove the front fascia: adım 4, 1 resimden 1.
    • Use a T5 Torx screwdriver to remove the following eight screws from the front fascia:
    • Four 6.3 mm screws with fine threads
    • Four 6.0 mm screws with coarse threads
  5. Valve Index Headset Motherboard Replacement: adım 5, 3 resimden 1. Valve Index Headset Motherboard Replacement: adım 5, 3 resimden 2. Valve Index Headset Motherboard Replacement: adım 5, 3 resimden 3.
    • Use a spudger to unlock the ZIF connector at the top-left corner of the motherboard.
    • Disconnect the FPC ribbon cable from the motherboard.
  6. Valve Index Headset Motherboard Replacement: adım 6, 3 resimden 1. Valve Index Headset Motherboard Replacement: adım 6, 3 resimden 2. Valve Index Headset Motherboard Replacement: adım 6, 3 resimden 3.
    • Use a spudger to unlock the ZIF connector at the top-right corner of the motherboard.
    • Disconnect the FPC ribbon cable.
  7. Valve Index Headset Motherboard Replacement: adım 7, 2 resimden 1. Valve Index Headset Motherboard Replacement: adım 7, 2 resimden 2.
    • Use the flat end of a spudger to disconnect the press connector from the bottom-left corner of the motherboard.
    • To re-attach press connectors like this one, carefully align and press down on one side until it clicks into place, then repeat on the other side. Do not press down on the middle. If the connector is misaligned, the pins can bend, causing permanent damage.
  8. Valve Index Headset Motherboard Replacement: adım 8, 2 resimden 1. Valve Index Headset Motherboard Replacement: adım 8, 2 resimden 2.
    • Use the flat end of a spudger to disconnect the press connector from the bottom-right corner of the motherboard.
  9. Valve Index Headset Motherboard Replacement: adım 9, 2 resimden 1. Valve Index Headset Motherboard Replacement: adım 9, 2 resimden 2.
    • Insert an opening pick in between the front fascia and the headset.
    • Slide the opening pick over to separate the front fascia from the headset.
  10. Valve Index Headset Motherboard Replacement: adım 10, 2 resimden 1. Valve Index Headset Motherboard Replacement: adım 10, 2 resimden 2.
    • Continue sliding the opening pick along the perimeter of the front fascia until all edges are free.
  11. Valve Index Headset Motherboard Replacement: adım 11, 2 resimden 1. Valve Index Headset Motherboard Replacement: adım 11, 2 resimden 2.
    • Remove the front fascia.
  12. Valve Index Headset Motherboard Replacement, Remove the motherboard: adım 12, 1 resimden 1.
    • Note the seven cables that must be disconnected in the following steps before the motherboard can be removed.
  13. Valve Index Headset Motherboard Replacement: adım 13, 3 resimden 1. Valve Index Headset Motherboard Replacement: adım 13, 3 resimden 2. Valve Index Headset Motherboard Replacement: adım 13, 3 resimden 3.
    • Use the flat end of a spudger to unlock the wide ZIF connector on the left side of the motherboard.
  14. Valve Index Headset Motherboard Replacement: adım 14, 2 resimden 1. Valve Index Headset Motherboard Replacement: adım 14, 2 resimden 2.
    • Use the flat end of a spudger to disconnect the press connector near the bottom-left edge of the motherboard.
    • During reassembly, be sure this cable is not trapped underneath the motherboard.
  15. Valve Index Headset Motherboard Replacement: adım 15, 3 resimden 1. Valve Index Headset Motherboard Replacement: adım 15, 3 resimden 2. Valve Index Headset Motherboard Replacement: adım 15, 3 resimden 3.
    • Use your finger or an opening tool to unlock the display cable connector at the top of the motherboard.
    • Carefully disconnect the display cable connector.
  16. Valve Index Headset Motherboard Replacement: adım 16, 2 resimden 1. Valve Index Headset Motherboard Replacement: adım 16, 2 resimden 2.
    • Use the pointed end of a spudger to gently disconnect the bundled cable connector from the top-right corner of the motherboard.
  17. Valve Index Headset Motherboard Replacement: adım 17, 3 resimden 1. Valve Index Headset Motherboard Replacement: adım 17, 3 resimden 2. Valve Index Headset Motherboard Replacement: adım 17, 3 resimden 3.
    • Use the pointed end of a spudger to unlock the ZIF connector next to the USB port on the motherboard.
    • Disconnect the FPC cable from the motherboard.
    • During reassembly, make sure this ribbon cable is not trapped under the motherboard.
  18. Valve Index Headset Motherboard Replacement: adım 18, 2 resimden 1. Valve Index Headset Motherboard Replacement: adım 18, 2 resimden 2.
    • Use the flat end of a spudger to disconnect the press connector below the USB port on the motherboard.
    • During reassembly, make sure this cable is not trapped under the motherboard.
  19. Valve Index Headset Motherboard Replacement: adım 19, 3 resimden 1. Valve Index Headset Motherboard Replacement: adım 19, 3 resimden 2. Valve Index Headset Motherboard Replacement: adım 19, 3 resimden 3.
    • Use a spudger to unlock the wide ZIF connector near the right edge of the motherboard.
  20. Valve Index Headset Motherboard Replacement: adım 20, 1 resimden 1.
    • Use a T5 Torx screwdriver to remove the five 6.0 mm screws securing the motherboard to the headset.
  21. Valve Index Headset Motherboard Replacement: adım 21, 2 resimden 1. Valve Index Headset Motherboard Replacement: adım 21, 2 resimden 2.
    • Grab the motherboard by the USB port and carefully remove it from the headset.
    • During reassembly, be very careful not to trap any of the previously disconnected cables under the motherboard.
Sonuç
Repair didn’t go as planned? Try some basic troubleshooting, or ask our Valve Index Answers community for help.
Bir başkası bu kılavuzu tamamladı.
Sam Omiotek
92.272 İtibar
290 adet Kılavuz yazıldı
5Kılavuz Yorumları
Where can I buy the motherboard? It doesn't look like ifixit has them.
Curtis Gray - Yanıt
I have this same question.
Patrick Hartge -
you would think the replacement motherboard would be in the list of required items. Where are you supposed to buy this from?
Grant Za - Yanıt
Same question ,where do i get a replacement main board
Gifted Misfit - Yanıt
Daniel O'Sullivan - Yanıt
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 4
Son 7 gün: 54
Son 30 gün: 306
Her zaman: 12,900
