Ana içeriğe geç
VanMoof S2 Bel and Boost Button Replacement
Amani
Amani ve başka bir katkıda bulunan
En son August 2, 2024 tarihinde güncellendi
10 - 25 dakika
Orta
Topluluk-Katkılı Kılavuz
This guide will show you how to replace the VanMoof S2 Bel and Boost button.
  1. VanMoof S2 Bel and Boost Button Replacement, Loosen the caliper: adım 1, 1 resimden 1.
    • Brake cable needs to be loosened at caliper, undo the bolt with a 5mm allen key (you don’t have to remove the bolt).
  2. VanMoof S2 Bel and Boost Button Replacement, Remove the brake from the lever: adım 2, 1 resimden 1.
    • Pull the right brake lever and remove the brake wire from the lever.
  3. VanMoof S2 Bel and Boost Button Replacement, Gain access to the cables: adım 3, 1 resimden 1.
    • Slide the outer sleeve of the cables up to gain access to the cable.
  4. VanMoof S2 Bel and Boost Button Replacement, Cut open the cable: adım 4, 1 resimden 1.
    • Cut the shrink sleeve open along the length of the cable. Be careful not to cut the cables or yourself.
  5. VanMoof S2 Bel and Boost Button Replacement, Disconnect the connectors: adım 5, 1 resimden 1.
    • Disconnect the connectors and cut off the connectors on the bike side.
  6. VanMoof S2 Bel and Boost Button Replacement, Strip the cables: adım 6, 1 resimden 1.
    • Strip both cables and connect them with your fingers to check if the wiring is ok (the bike should be switching power levels while bike is on).
  7. VanMoof S2 Bel and Boost Button Replacement, Time to solder: adım 7, 1 resimden 1.
    • If this is working, solder the non-connector side of the extended cable to the stripped cable on the bike side (if this is not working, bike needs to be shipped to VanMoof).
  8. VanMoof S2 Bel and Boost Button Replacement, Get the cables in the frame: adım 8, 1 resimden 1.
    • Push the cable in the frame, try to push it down and not back (towards the display). To check if it is pushed in properly, turn the handle bar as far to the left as possible. You should feel a firm stop, compare this with the right side. If it feels soft (damped) reinsert the cable and test again.
  9. VanMoof S2 Bel and Boost Button Replacement, Re-connect the connectors: adım 9, 1 resimden 1.
    • Re-connect the connectors from the extended cable to the connectors on the button side again.
  10. VanMoof S2 Bel and Boost Button Replacement, Testing the button: adım 10, 1 resimden 1.
    • Test the button (if it switches power levels while the bike is turned on).
  11. VanMoof S2 Bel and Boost Button Replacement, Re-attach the brake: adım 11, 1 resimden 1.
    • If it works correctly, re-attach the brake cable.
  12. VanMoof S2 Bel and Boost Button Replacement, Fixed!: adım 12, 1 resimden 1.
    • Boost button is extended and fixed.
Sonuç
Amani
207 İtibar
1 Kılavuz yazıldı
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 2
Son 30 gün: 11
Her zaman: 108
