Ana içeriğe geç
Velbon CX690 Tripod Mounting Plate Cap Replacement
Neye ihtiyacın var
  1. Velbon CX690 Tripod Mounting Plate Cap Replacement, Mounting Plate Cap: adım 1, 2 resimden 1. Velbon CX690 Tripod Mounting Plate Cap Replacement, Mounting Plate Cap: adım 1, 2 resimden 2.
    • Grab the quick-release plate with one hand and the tripod body with the other. Then, pull the quick-release plate straight off of the tripod body.
    • The quick-release plate may need to be twisted off of the tripod body if it does not slide off.
  2. Velbon CX690 Tripod Mounting Plate Cap Replacement: adım 2, 2 resimden 1. Velbon CX690 Tripod Mounting Plate Cap Replacement: adım 2, 2 resimden 2.
    • Grab the side-tilt-locking-nut with your dominant hand and grab the pan handle with your other hand. Twist the side-tilt-locking-nut counterclockwise to loosen it, and then pull it off.
  3. Velbon CX690 Tripod Mounting Plate Cap Replacement: adım 3, 2 resimden 1. Velbon CX690 Tripod Mounting Plate Cap Replacement: adım 3, 2 resimden 2.
    • Grab the pan handle with your dominant hand and grab the quick-release plate with the other. Twist the pan handle counterclockwise until loose and then pull it off of the quick-release plate.
    • Make sure to leave the washer on the pan handle.
  4. Velbon CX690 Tripod Mounting Plate Cap Replacement: adım 4, 2 resimden 1. Velbon CX690 Tripod Mounting Plate Cap Replacement: adım 4, 2 resimden 2.
    • Grab the pan head of the quick-release plate with your dominant hand and the other part of the quick-release plate with your other hand. Then, rotate the pan head clockwise 90 degrees.
  5. Velbon CX690 Tripod Mounting Plate Cap Replacement: adım 5, 2 resimden 1. Velbon CX690 Tripod Mounting Plate Cap Replacement: adım 5, 2 resimden 2.
    • Using the more narrow part of the tripod body, place the quick-release plate back onto the tripod body.
  6. Velbon CX690 Tripod Mounting Plate Cap Replacement: adım 6, 1 resimden 1.
    • In order to reattach the mounting cap, use JB Weld to make a welding solution.
    • Mix the JB Weld solution in a circular motion for about 30 seconds or until it turns grey.
  7. Velbon CX690 Tripod Mounting Plate Cap Replacement: adım 7, 1 resimden 1.
    • Apply the JB Weld solution to the top of the center column of the tripod body.
    • Do not apply JB Weld solution to the inside of the center column.
    • Do this quickly because the JB Weld solution cures rapidly.
  8. Velbon CX690 Tripod Mounting Plate Cap Replacement: adım 8, 3 resimden 1. Velbon CX690 Tripod Mounting Plate Cap Replacement: adım 8, 3 resimden 2. Velbon CX690 Tripod Mounting Plate Cap Replacement: adım 8, 3 resimden 3.
    • Retrieve the mounting cap and hold it on the top of the center column for 60 seconds or until it feels secure.
  9. Velbon CX690 Tripod Mounting Plate Cap Replacement: adım 9, 2 resimden 1. Velbon CX690 Tripod Mounting Plate Cap Replacement: adım 9, 2 resimden 2.
    • Hold the pan handle with your dominant hand. Rotate the mounting plate clockwise, until it gets to the position you would like for use.
    • The position can be changed later by loosening the pan handle.
  10. Velbon CX690 Tripod Mounting Plate Cap Replacement: adım 10, 2 resimden 1. Velbon CX690 Tripod Mounting Plate Cap Replacement: adım 10, 2 resimden 2.
    • Insert the pan handle back into its original hole. Rotate the pan handle clockwise. Make sure the washer is still connected and tighten until it feels tight.
    • Do not use excessive force when tightening the pan handle.
  11. Velbon CX690 Tripod Mounting Plate Cap Replacement: adım 11, 2 resimden 1. Velbon CX690 Tripod Mounting Plate Cap Replacement: adım 11, 2 resimden 2.
    • Insert the side-tilt-locking nut into the hole it came out of. Rotate the side-tilt-locking nut clockwise, until it feels tight.
    • Do not use excessive force when tightening the side tilt locking nut.
Bitiş Çizgisi
2 farklı kişi bu kılavuzu tamamladı.
Jordan Schleifer
110 İtibar
1 Kılavuz yazıldı
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 6
Son 30 gün: 14
Her zaman: 1,182
