Ana içeriğe geç
Velocity Micro Cruz T301 Battery Replacement
Neye ihtiyacın var
  1. Velocity Micro Cruz T301 Battery Replacement, Battery: adım 1, 1 resimden 1.
    • Insert the plastic iFixit opening tool into the SD port. Orient the iFixit opening tool so that the edge faces the rear panel.
  2. Velocity Micro Cruz T301 Battery Replacement: adım 2, 1 resimden 1.
    • Use the iFixit opening tools to pry open a gap between the tablet and rear panel.
  3. Velocity Micro Cruz T301 Battery Replacement: adım 3, 2 resimden 1. Velocity Micro Cruz T301 Battery Replacement: adım 3, 2 resimden 2.
    • Move the small tool opener around the rear panel to free the 12 clips.
  4. Velocity Micro Cruz T301 Battery Replacement: adım 4, 1 resimden 1.
    • Remove the four screws in the metal battery housing using the Phillips #0 screwdriver.
  5. Velocity Micro Cruz T301 Battery Replacement: adım 5, 1 resimden 1.
    • Disconnect the battery using the spudger.
  6. Velocity Micro Cruz T301 Battery Replacement: adım 6, 1 resimden 1.
    • Lift the battery out of its place with a nylon spudger.
    • This photo shows the use of an incorrect tool. Always use an ESD safe tool, like the nylon spudger, when dealing with delicate components.
Sonuç
Bir başkası bu kılavuzu tamamladı.
Ali Rashid Al Araimi
371 İtibar
3 adet Kılavuz yazıldı
Ekip
USF Tampa, Team 1-6, Cagle Fall 2016 USF Tampa, Team 1-6, Cagle Fall 2016 üyesi
USFT-CAGLE-F16S1G6
3 Üyeler
5 adet Kılavuz yazıldı
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 1
Son 30 gün: 11
Her zaman: 549
