Verizon Ellipsis Jetpack MHS800L Plastic Case Replacement
Giriş
1. adıma gitWhat you can expect from this guide is a step by step process on how to remove the plastic case on a Verizon Ellipsis Jetpack MHS800L.
Neye ihtiyacın var
Bu adımda kullanılan alet:Phillips #00 Screwdriver$5.49
With the device on its back and the label facing you, remove the rubber screw cover on the top left corner of the device.
Under the rubber circle, remove the 1.25 mm screw using a Phillips #00 Screwdriver.
Bu adımda kullanılan alet:iFixit Opening Picks (Set of 6)$4.99
Use a plastic pick at the seams and pry open the case.
2 farklı kişi bu kılavuzu tamamladı.
