Ana içeriğe geç
Verizon Jetpack 4G LTE Mobile Hotspot Buttons Replacement
Neye ihtiyacın var
  1. Verizon Jetpack 4G LTE Mobile Hotspot Buttons Replacement, Battery: adım 1, 2 resimden 1. Verizon Jetpack 4G LTE Mobile Hotspot Buttons Replacement, Battery: adım 1, 2 resimden 2.
    • Hold the device with your non-dominant hand, looking at the back of the device, taking note of the small notch along the edge.
  2. Verizon Jetpack 4G LTE Mobile Hotspot Buttons Replacement: adım 2, 2 resimden 1. Verizon Jetpack 4G LTE Mobile Hotspot Buttons Replacement: adım 2, 2 resimden 2.
    • While holding the device with your non-dominant hand, use your dominant hand to gently pry the back casing off the device. The most effective way to do this is by gripping the small notch.
    • If it doesn't come off, try using alternative grips that are the most comfortable for you. Try using your fingernails to pry up at the corner or around the edge of the backing. The case should come off easily.
    • The back should be completely removed.
  3. Verizon Jetpack 4G LTE Mobile Hotspot Buttons Replacement: adım 3, 1 resimden 1.
    • The battery should now be visible. Gently grasp the edges to lift it out of the device.
    • The device in picture no longer has a battery but a normal device will likely have a battery once opened.
  4. Verizon Jetpack 4G LTE Mobile Hotspot Buttons Replacement, SIM Card: adım 4, 1 resimden 1.
    • Now that the battery is out, the SIM Card should be visible. Simply grasp it and pull it out of the device.
    • The device in picture no longer has a SIM card but a normal device will likely have a SIM card once opened.
  5. Verizon Jetpack 4G LTE Mobile Hotspot Buttons Replacement, Screen: adım 5, 2 resimden 1. Verizon Jetpack 4G LTE Mobile Hotspot Buttons Replacement, Screen: adım 5, 2 resimden 2.
    • Using a Phillips #000 screwdriver, remove the screws found on the four corners of the back of the device.
    • The device pictured is extremely damaged. A normal device should not appear as bent and broken.
    • The screws are very small and may require some patience to get a proper grip.
  6. Verizon Jetpack 4G LTE Mobile Hotspot Buttons Replacement: adım 6, 3 resimden 1. Verizon Jetpack 4G LTE Mobile Hotspot Buttons Replacement: adım 6, 3 resimden 2. Verizon Jetpack 4G LTE Mobile Hotspot Buttons Replacement: adım 6, 3 resimden 3.
    • Using the metal spudger, pry the plastic casing around the device.
  7. Verizon Jetpack 4G LTE Mobile Hotspot Buttons Replacement: adım 7, 2 resimden 1. Verizon Jetpack 4G LTE Mobile Hotspot Buttons Replacement: adım 7, 2 resimden 2.
    • Using the metal spudger, gently pull out the motherboard from the plastic casing.
  8. Verizon Jetpack 4G LTE Mobile Hotspot Buttons Replacement: adım 8, 3 resimden 1. Verizon Jetpack 4G LTE Mobile Hotspot Buttons Replacement: adım 8, 3 resimden 2. Verizon Jetpack 4G LTE Mobile Hotspot Buttons Replacement: adım 8, 3 resimden 3.
    • Rotate the motherboard so that the screen is facing you.
    • Gently pull up the orange tape to remove the screen.
  9. Verizon Jetpack 4G LTE Mobile Hotspot Buttons Replacement, Buttons: adım 9, 3 resimden 1. Verizon Jetpack 4G LTE Mobile Hotspot Buttons Replacement, Buttons: adım 9, 3 resimden 2. Verizon Jetpack 4G LTE Mobile Hotspot Buttons Replacement, Buttons: adım 9, 3 resimden 3.
    • Now that the motherboard is out, the buttons should come easily out of what's left of the device. If they do not fall out once the motherboard is out, simply poke the buttons from the front and they should separate from the device.
Sonuç
Bir başkası bu kılavuzu tamamladı.
Madison Asaro
243 İtibar
2 adet Kılavuz yazıldı
Ekip
Marist, Team S1-G3, Chaterdon Fall 2018 Marist, Team S1-G3, Chaterdon Fall 2018 üyesi
MARS-CHATERDON-F18S1G3
3 Üyeler
8 adet Kılavuz yazıldı
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 3
Son 30 gün: 5
Her zaman: 853
