Ana içeriğe geç
Visual Land Prestige Elite 7Q Battery Replacement
Neye ihtiyacın var
    1. Visual Land Prestige Elite 7Q Battery Replacement, Battery: adım 1, 2 resimden 1. Visual Land Prestige Elite 7Q Battery Replacement, Battery: adım 1, 2 resimden 2.
      • At the bottom of the tablet, remove the two 3.6mm screws with a Phillips #000 screwdriver.
      FixBot'a Sor
      Yorum Ekle
    2. Visual Land Prestige Elite 7Q Battery Replacement: adım 2, 2 resimden 1. Visual Land Prestige Elite 7Q Battery Replacement: adım 2, 2 resimden 2.
      • Wedge a plastic opening tool into the edges of the tablet to pry it open.
      FixBot'a Sor
      Yorum Ekle
    3. Visual Land Prestige Elite 7Q Battery Replacement: adım 3, 2 resimden 1. Visual Land Prestige Elite 7Q Battery Replacement: adım 3, 2 resimden 2.
      • Peel off the yellow tape holding down the battery.
      FixBot'a Sor
      Yorum Ekle
    4. Visual Land Prestige Elite 7Q Battery Replacement: adım 4, 2 resimden 1. Visual Land Prestige Elite 7Q Battery Replacement: adım 4, 2 resimden 2.
      Bu adımda kullanılan alet:
      Plastic Cards
      $2.99
      • Use a plastic card to loosen the battery from the tablet. Note that it will be sticky underneath the battery.
      FixBot'a Sor
      Yorum Ekle
    5. Visual Land Prestige Elite 7Q Battery Replacement: adım 5, 3 resimden 1. Visual Land Prestige Elite 7Q Battery Replacement: adım 5, 3 resimden 2. Visual Land Prestige Elite 7Q Battery Replacement: adım 5, 3 resimden 3.
      • Soldering iron gets hot. For information on how to use a soldering iron, click here.
      • Use a soldering iron to detach the battery wires from the motherboard.
      • Replace the battery.
      FixBot'a Sor
      Yorum Ekle
Sonuç
Sabrina Scholten
621 İtibar
6 adet Kılavuz yazıldı
Ekip
UC Davis, Team 2-1, Oliver Fall 2016 UC Davis, Team 2-1, Oliver Fall 2016 üyesi
UCD-OLIVER-F16S2G1
5 Üyeler
18 adet Kılavuz yazıldı
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 1
Son 7 gün: 3
Son 30 gün: 28
Her zaman: 1,409
