Ana içeriğe geç
Visual Land Prestige Pro 7D Battery Replacement
Neye ihtiyacın var
    1. Visual Land Prestige Pro 7D Battery Replacement, Back Panel: adım 1, 1 resimden 1.
      • Unscrew the two 4.0mm Phillips head screws found near the ports at the bottom of the device using a PH #00 screwdriver.
      FixBot'a Sor
      Yorum Ekle
    2. Visual Land Prestige Pro 7D Battery Replacement: adım 2, 1 resimden 1.
      • Be careful when taking the back panel off. The speaker is connected to both the front and back panels, and may get pulled out if you are not gentle when lifting the back panel away.
      • Slide the plastic prying tool in between the front and back panel and pry them apart on all 4 sides.
      • It may be easiest to start on one of the sides, and work your way around the device. The bottom, with the ports, is the most difficult side and can be saved for last.
      • There are small latches that make this difficult. Moderate force may be required to separate the two panels.
      FixBot'a Sor
      Yorum Ekle
    1. Visual Land Prestige Pro 7D Battery Replacement, Battery: adım 3, 1 resimden 1.
      • Pry a thin tool under the battery.
      • Be gentle and try not to bend the battery.
      • Slide the tool around all sides of the battery. Separate it evenly on all sides for the best result.
      FixBot'a Sor
      Yorum Ekle
    2. Visual Land Prestige Pro 7D Battery Replacement: adım 4, 2 resimden 1. Visual Land Prestige Pro 7D Battery Replacement: adım 4, 2 resimden 2.
      • Soldering guns are hot and can easily damage the device.
      • Desolder the two connections between the red and blue wires where the battery connects to the circuit board.Soldering guns are hot and can easily damage the device.
      • For soldering information, see our guide: Lehimleme ve Lehim Sökme Bağlantıları Nasıl Yapılır.
      • If you are removing the LCD display this step is unnecessary.
      FixBot'a Sor
      Yorum Ekle
Sonuç
3 farklı kişi bu kılavuzu tamamladı.
Max Hudson
422 İtibar
2 adet Kılavuz yazıldı
Ekip
Cal Poly, Team 10-41, Amido Fall 2014 Cal Poly, Team 10-41, Amido Fall 2014 üyesi
CPSU-AMIDO-F14S10G41
4 Üyeler
12 adet Kılavuz yazıldı
1Rehber Yorum
My tablet shows the icon battery What that mean
paularslay - Yanıt Paylaş
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 1
Son 7 gün: 6
Son 30 gün: 33
Her zaman: 6,447
