Ana içeriğe geç
Visual Land Prestige Pro 7D Reset Button Replacement
Neye ihtiyacın var
    1. Visual Land Prestige Pro 7D Reset Button Replacement, Back Panel: adım 1, 1 resimden 1.
      • Unscrew the two 4.0mm Phillips head screws found near the ports at the bottom of the device using a PH #00 screwdriver.
      FixBot'a Sor
      Yorum Ekle
    2. Visual Land Prestige Pro 7D Reset Button Replacement: adım 2, 1 resimden 1.
      • Be careful when taking the back panel off. The speaker is connected to both the front and back panels, and may get pulled out if you are not gentle when lifting the back panel away.
      • Slide the plastic prying tool in between the front and back panel and pry them apart on all 4 sides.
      • It may be easiest to start on one of the sides, and work your way around the device. The bottom, with the ports, is the most difficult side and can be saved for last.
      • There are small latches that make this difficult. Moderate force may be required to separate the two panels.
      FixBot'a Sor
      Yorum Ekle
    1. Visual Land Prestige Pro 7D Reset Button Replacement, Reset Button: adım 3, 2 resimden 1. Visual Land Prestige Pro 7D Reset Button Replacement, Reset Button: adım 3, 2 resimden 2.
      Bu adımda kullanılan alet:
      • Use the tweezers to lift the grey connector, located next to the reset button, up from the beige housing. It should rotate up, and allow you to slide the ribbon out from under the connector.
      • Although not necessary for replacing the reset button, it is highly recommended to disconnect the ribbon. This ensures it will not get damaged during desoldering.
      FixBot'a Sor
      Yorum Ekle
    2. Visual Land Prestige Pro 7D Reset Button Replacement: adım 4, 3 resimden 1. Visual Land Prestige Pro 7D Reset Button Replacement: adım 4, 3 resimden 2. Visual Land Prestige Pro 7D Reset Button Replacement: adım 4, 3 resimden 3.
      FixBot'a Sor
      Yorum Ekle
Sonuç
3 farklı kişi bu kılavuzu tamamladı.
Jennifer Laybourn
353 İtibar
2 adet Kılavuz yazıldı
Ekip
Cal Poly, Team 10-41, Amido Fall 2014 Cal Poly, Team 10-41, Amido Fall 2014 üyesi
CPSU-AMIDO-F14S10G41
4 Üyeler
12 adet Kılavuz yazıldı
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 6
Son 30 gün: 31
Her zaman: 3,932
