Ana içeriğe geç
Vivitar Vivicam T027 Power Button Replacement
Neye ihtiyacın var
  1. Vivitar Vivicam T027 Power Button Replacement, Power Button: adım 1, 2 resimden 1. Vivitar Vivicam T027 Power Button Replacement, Power Button: adım 1, 2 resimden 2.
    • Using a Phillips #00 screwdriver, remove four exposed 3mm screws.
    • You will find one screw on the top, one on the bottom, and one on each side of the camera.
    • Put the screws in a safe place so you can find them and put them back in later.
  2. Vivitar Vivicam T027 Power Button Replacement: adım 2, 1 resimden 1.
    • Remove the sticker on the top of the camera.
    • Use the Phillips #00 screwdriver to remove the screw that was underneath the sticker.
  3. Vivitar Vivicam T027 Power Button Replacement: adım 3, 2 resimden 1. Vivitar Vivicam T027 Power Button Replacement: adım 3, 2 resimden 2.
    • Separate the front and the back of the camera completely to expose the motherboard.
  4. Vivitar Vivicam T027 Power Button Replacement: adım 4, 1 resimden 1.
    Bu adımda kullanılan alet:
    • Locate the power button on the top of the camera.
    • Using tweezers, gently remove the black plastic cover from the power button.
  5. Vivitar Vivicam T027 Power Button Replacement: adım 5, 2 resimden 1. Vivitar Vivicam T027 Power Button Replacement: adım 5, 2 resimden 2.
    • Using a soldering kit, de-solder the black and red wire from the silver power button.
    • Solder the new power button to the black and red wire.
    • To avoid burns, be careful of the heat from the soldering iron.
    • Reference the soldering guide for assistance!
Sonuç
Dana
110 İtibar
1 Kılavuz yazıldı
Ekip
Marist, Team 15-13, Laflen Spring 2015 Marist, Team 15-13, Laflen Spring 2015 üyesi
MARS-LAFLEN-S15S15G13
4 Üyeler
3 adet Kılavuz yazıldı
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 1
Son 30 gün: 5
Her zaman: 980
