Bu sürüm, hatalı düzenlemeler içerebilir. En son doğrulanmış bellek kopyası dönün.
Neye ihtiyacın var
Bu adım çevrilmemiş. Çevrilmesine yardım edin
Using a Phillips #00 screwdriver, remove four exposed 3mm screws.
You will find one screw on the top, one on the bottom, and one on each side of the camera.
Remove the sticker on the top of the camera.
Use the Phillips #00 screwdriver to remove the screw that was underneath the sticker.
Separate the front and the back of the camera completely to expose the motherboard.
Bu adımda kullanılan alet:Tweezers$4.99-
Locate the power button on the top of the camera.
Using tweezers, gently remove the black plastic cover from the power button.
Using a soldering kit, de-solder the black and red wire from the silver power button.
Solder the new power button to the black and red wire.
