Ana içeriğe geç
Vizio SmartCast Crave 360 Bass Replacement
Neye ihtiyacın var
  1. Vizio SmartCast Crave 360 Bass Replacement, Bottom Panel: adım 1, 2 resimden 1. Vizio SmartCast Crave 360 Bass Replacement, Bottom Panel: adım 1, 2 resimden 2.
    • Orient the speaker so that the bottom faces up.
    • Peel the rubber ring off of the bottom using the spudger.
  2. Vizio SmartCast Crave 360 Bass Replacement: adım 2, 1 resimden 1.
    • Remove the eight 5 mm screws connecting the bottom panel to the gray power port using a Phillips #000 screwdriver.
  3. Vizio SmartCast Crave 360 Bass Replacement: adım 3, 2 resimden 1. Vizio SmartCast Crave 360 Bass Replacement: adım 3, 2 resimden 2.
    • Lift the gray power port and move it to the side to reveal the bass.
    • Do not touch the wire that runs from the power port to the bottom of the bass component.
  4. Vizio SmartCast Crave 360 Bass Replacement, Bass: adım 4, 2 resimden 1. Vizio SmartCast Crave 360 Bass Replacement, Bass: adım 4, 2 resimden 2.
    • Remove the collar that wraps around the bass component.
    • Once the collar is removed, the speaker should appear similar to the speaker shown in the second photo.
  5. Vizio SmartCast Crave 360 Bass Replacement: adım 5, 3 resimden 1. Vizio SmartCast Crave 360 Bass Replacement: adım 5, 3 resimden 2. Vizio SmartCast Crave 360 Bass Replacement: adım 5, 3 resimden 3.
    • Remove the four 10 mm screws with that connect the bass to the rest of the speaker using a Phillips #000 screwdriver.
    • Take the bass component out of the speaker.
    • Disconnect the wiring that runs into the bass component.
    • The bass is now removed.
Sonuç
4 farklı kişi bu kılavuzu tamamladı.
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 1
Son 7 gün: 3
Son 30 gün: 20
Her zaman: 677
