Ana içeriğe geç
Vizio SmartCast Crave 360 Battery Replacement
Neye ihtiyacın var
  1. Vizio SmartCast Crave 360 Battery Replacement, Bottom Panel: adım 1, 2 resimden 1. Vizio SmartCast Crave 360 Battery Replacement, Bottom Panel: adım 1, 2 resimden 2.
    • Orient the speaker so that the bottom faces up.
    • Peel the rubber ring off of the bottom using the spudger.
  2. Vizio SmartCast Crave 360 Battery Replacement: adım 2, 1 resimden 1.
    • Remove the eight 5 mm screws connecting the bottom panel to the gray power port using a Phillips #000 screwdriver.
  3. Vizio SmartCast Crave 360 Battery Replacement: adım 3, 2 resimden 1. Vizio SmartCast Crave 360 Battery Replacement: adım 3, 2 resimden 2.
    • Lift the gray power port and move it to the side to reveal the bass.
    • Do not touch the wire that runs from the power port to the bottom of the bass component.
  4. Vizio SmartCast Crave 360 Battery Replacement, Bass: adım 4, 2 resimden 1. Vizio SmartCast Crave 360 Battery Replacement, Bass: adım 4, 2 resimden 2.
    • Remove the collar that wraps around the bass component.
    • Once the collar is removed, the speaker should appear similar to the speaker shown in the second photo.
  5. Vizio SmartCast Crave 360 Battery Replacement: adım 5, 3 resimden 1. Vizio SmartCast Crave 360 Battery Replacement: adım 5, 3 resimden 2. Vizio SmartCast Crave 360 Battery Replacement: adım 5, 3 resimden 3.
    • Remove the four 10 mm screws with that connect the bass to the rest of the speaker using a Phillips #000 screwdriver.
    • Take the bass component out of the speaker.
    • Disconnect the wiring that runs into the bass component.
    • The bass is now removed.
  6. Vizio SmartCast Crave 360 Battery Replacement, Battery: adım 6, 2 resimden 1. Vizio SmartCast Crave 360 Battery Replacement, Battery: adım 6, 2 resimden 2.
    • Flip the speaker to access the top.
    • Remove the eight 10 mm screws from the plastic disc inside the grey speaker cage using a Phillips #000 screwdriver.
    • Remove the plastic disc from the speaker cage.
  7. Vizio SmartCast Crave 360 Battery Replacement: adım 7, 1 resimden 1.
    • Lift the grey speaker cage to reveal a black plastic cylinder that contains the battery.
  8. Vizio SmartCast Crave 360 Battery Replacement: adım 8, 2 resimden 1. Vizio SmartCast Crave 360 Battery Replacement: adım 8, 2 resimden 2.
    • Disconnect the wire that connects the motherboard to the battery.
  9. Vizio SmartCast Crave 360 Battery Replacement: adım 9, 2 resimden 1. Vizio SmartCast Crave 360 Battery Replacement: adım 9, 2 resimden 2.
    • Remove the motherboard and battery from the plastic cylinder.
  10. Vizio SmartCast Crave 360 Battery Replacement: adım 10, 1 resimden 1.
    • Remove the four 5 mm screws from the motherboard using a Phillips #000 screwdriver.
  11. Vizio SmartCast Crave 360 Battery Replacement: adım 11, 1 resimden 1.
    • Remove the motherboard from the battery.
Sonuç
Bir başkası bu kılavuzu tamamladı.
Bir Yorum
Any other way to charge the battery without the charging station or is there a compatible charging station?
Trading Azteca - Yanıt
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 2
Son 7 gün: 16
Son 30 gün: 77
Her zaman: 1,078
