Ana içeriğe geç
Volleyball Valve Replacement
Neye ihtiyacın var
  1. Volleyball Valve Replacement, Valve: adım 1, 1 resimden 1.
    • Bend a thin metal wire into a hook.
    • This is what we will be using to wiggle the air valve out.
  2. Volleyball Valve Replacement: adım 2, 1 resimden 1.
    • Insert the wire into the valve and use it to hook and pull out the valve as much as possible. .
    • This process might take awhile depending how broken the valve is.
  3. Volleyball Valve Replacement: adım 3, 1 resimden 1.
    • Once a piece of the valve is sticking out, use the needle nose pliers to pull out the valve.
  4. Volleyball Valve Replacement: adım 4, 1 resimden 1.
    • With your new valve, place it to the hole where the previous valve was, and use the screwdriver to push it in until it is flush with the surface of the ball.
  5. Volleyball Valve Replacement: adım 5, 1 resimden 1.
    • You are done! The volleyball valve has been replaced and should not let any air out.
Sonuç
Justin Nadela
121 İtibar
1 Kılavuz yazıldı
Ekip
Bir Yorum
Thanks for this!!
Can you please let me know what valves to buy?
(my email address is sendtojfk@gmail.com)
Thanks!
Justin Kern - Yanıt
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 6
Son 7 gün: 26
Son 30 gün: 94
Her zaman: 3,942
