Ana içeriğe geç
Vtech Innotab 3 Microphone Replacement
Neye ihtiyacın var
    1. Vtech Innotab 3 Microphone Replacement, Rear Panel: adım 1, 3 resimden 1. Vtech Innotab 3 Microphone Replacement, Rear Panel: adım 1, 3 resimden 2. Vtech Innotab 3 Microphone Replacement, Rear Panel: adım 1, 3 resimden 3.
      • Slide the battery compartment door lock down.
      • While still holding the battery compartment lock down, slide the two battery doors outwards on either side of the device.
      • Carefully remove the batteries from the battery compartment.
      • The standard option for the InnoTab 3 is four AA batteries. Vtech also offers a rechargeable battery online, but both battery options are removed from the device the same way.
      FixBot'a Sor
      Yorum Ekle
    2. Vtech Innotab 3 Microphone Replacement: adım 2, 1 resimden 1.
      • Remove the six 7.6mm screws found in the battery compartment using a PH00 screwdriver.
      FixBot'a Sor
      Yorum Ekle
    3. Vtech Innotab 3 Microphone Replacement: adım 3, 3 resimden 1. Vtech Innotab 3 Microphone Replacement: adım 3, 3 resimden 2. Vtech Innotab 3 Microphone Replacement: adım 3, 3 resimden 3.
      • There are three hidden screws on the back of the device, two at the top and one near the bottom.
      • Using a nylon or metal spudger, remove the three caps that hide the screws.
      • Remove the 5mm screw near the bottom and the two 7.6mm at the top using a PH00 screwdriver.
      FixBot'a Sor
      Yorum Ekle
    4. Vtech Innotab 3 Microphone Replacement: adım 4, 1 resimden 1.
      • Carefully separate the back panel from the front panel revealing the motherboard connected to the front panel.
      FixBot'a Sor
      Yorum Ekle
    1. Vtech Innotab 3 Microphone Replacement, Microphone: adım 5, 3 resimden 1. Vtech Innotab 3 Microphone Replacement, Microphone: adım 5, 3 resimden 2. Vtech Innotab 3 Microphone Replacement, Microphone: adım 5, 3 resimden 3.
      • Remove the four 7.6 mm screws using a PH00 screwdriver.
      • Lift up the circuit board from the device.
      FixBot'a Sor
      Yorum Ekle
    2. Vtech Innotab 3 Microphone Replacement: adım 6, 3 resimden 1. Vtech Innotab 3 Microphone Replacement: adım 6, 3 resimden 2. Vtech Innotab 3 Microphone Replacement: adım 6, 3 resimden 3.
      Bu adımda kullanılan alet:
      • To replace the microphone, desolder the two connections that connect the speaker to the device.
      • Use tweezers to keep the microphone steady as you desolder the connections.
      • This is a tricky step. Refer to this guide to learn how to solder: How To Solder and Desolder Connections
      FixBot'a Sor
      Yorum Ekle
Sonuç
Zach Diviney
419 İtibar
4 adet Kılavuz yazıldı
Ekip
Colorado Springs, Team 5-4, Panko Spring 2015 Colorado Springs, Team 5-4, Panko Spring 2015 üyesi
UCCS-PANKO-S15S5G4
3 Üyeler
10 adet Kılavuz yazıldı
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 6
Son 30 gün: 20
Her zaman: 656
