Ana içeriğe geç
Vtech Kidibeats Drum Set Volume Switch Replacement
Neye ihtiyacın var
  1. Vtech Kidibeats Drum Set Volume Switch Replacement, Back Panel: adım 1, 1 resimden 1.
    • Locate the battery panel that is centered between the three leg supports at the bottom of the drum set.
  2. Vtech Kidibeats Drum Set Volume Switch Replacement: adım 2, 1 resimden 1.
    • To remove the battery panel, loosen the 10 mm panel screw using a flathead 4.0 screwdriver.
    • You can also use a small coin to loosen the screw.
  3. Vtech Kidibeats Drum Set Volume Switch Replacement: adım 3, 1 resimden 1.
    • Using your fingers, pry open and remove the back battery panel.
  4. Vtech Kidibeats Drum Set Volume Switch Replacement: adım 4, 1 resimden 1.
    • Use your fingers to remove each battery from its housing.
  5. Vtech Kidibeats Drum Set Volume Switch Replacement: adım 5, 1 resimden 1.
    • Using a Phillips #2 screwdriver, loosen and remove the six 14 mm screws.
  6. Vtech Kidibeats Drum Set Volume Switch Replacement: adım 6, 2 resimden 1. Vtech Kidibeats Drum Set Volume Switch Replacement: adım 6, 2 resimden 2.
    • With your hands, separate the bottom panel from the drum set.
    • When removing the bottom panel, be careful not to pull too hard in order to prevent damaging the connections from the motherboard to the speaker and power source.
  7. Vtech Kidibeats Drum Set Volume Switch Replacement, Volume Switch: adım 7, 1 resimden 1.
    • Loosen and remove the two 8 mm screws using a Phillips #00 screwdriver.
  8. Vtech Kidibeats Drum Set Volume Switch Replacement: adım 8, 1 resimden 1.
    • Use your fingers to gently remove the volume switch from its setting.
  9. Vtech Kidibeats Drum Set Volume Switch Replacement: adım 9, 1 resimden 1.
Sonuç
Bir başkası bu kılavuzu tamamladı.
Aaron Klementowski
820 İtibar
6 adet Kılavuz yazıldı
Ekip
USF Tampa, Team 2-8, Cagle Spring 2016 USF Tampa, Team 2-8, Cagle Spring 2016 üyesi
USFT-CAGLE-S16S2G8
2 Üyeler
12 adet Kılavuz yazıldı
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 1
Son 7 gün: 2
Son 30 gün: 19
Her zaman: 641
