Ana içeriğe geç
Vtech Kidizoom Smart Watch DX Battery Replacement
Neye ihtiyacın var
  1. Vtech Kidizoom Smart Watch DX Battery Replacement, Master Switch: adım 1, 1 resimden 1.
    • Make sure the master switch is "OFF" before disassembly, to avoid an electric shock.
    • Flip the watch over with the back facing up.
  2. Vtech Kidizoom Smart Watch DX Battery Replacement: adım 2, 1 resimden 1.
    • Remove the four 6.0 mm screws on the back plate with the Phillips #00 screwdriver.
  3. Vtech Kidizoom Smart Watch DX Battery Replacement: adım 3, 1 resimden 1.
    • Gently pull the back plate from the watch casing.
  4. Vtech Kidizoom Smart Watch DX Battery Replacement: adım 4, 2 resimden 1. Vtech Kidizoom Smart Watch DX Battery Replacement: adım 4, 2 resimden 2.
    • Lift the master switch from the circuit board.
  5. Vtech Kidizoom Smart Watch DX Battery Replacement, Circuit Board: adım 5, 2 resimden 1. Vtech Kidizoom Smart Watch DX Battery Replacement, Circuit Board: adım 5, 2 resimden 2.
    • The speaker wires are fragile. They may break if excessive force is used to remove the circuit board.
    • Removal of the circuit board requires soldering.
    • Gently push on the display from the front, near the camera. The circuit board and display will pop out through the back.
  6. Vtech Kidizoom Smart Watch DX Battery Replacement: adım 6, 1 resimden 1.
    • Lift the circuit board carefully from the casing, without breaking or detaching the speaker wires at the bottom of the circuit board.
  7. Vtech Kidizoom Smart Watch DX Battery Replacement: adım 7, 1 resimden 1.
    • Note which wire is connected to which lead before continuing. There are no markers on the circuit board to indicate where each wire belongs.
    • De-solder the black speaker wire from the circuit board.
  8. Vtech Kidizoom Smart Watch DX Battery Replacement: adım 8, 1 resimden 1.
    • De-solder the red speaker wire, as in the previous step.
  9. Vtech Kidizoom Smart Watch DX Battery Replacement: adım 9, 1 resimden 1.
    • Wait for the solder to cool down and solidify, then remove the circuit board from the casing.
  10. Vtech Kidizoom Smart Watch DX Battery Replacement, Battery: adım 10, 2 resimden 1. Vtech Kidizoom Smart Watch DX Battery Replacement, Battery: adım 10, 2 resimden 2.
    • Using the plastic opening tool, gently pry the edges of the battery away from from the circuit board.
    • There is a thin layer of adhesive holding the battery to the circuit board. This will remain sticky after prying.
  11. Vtech Kidizoom Smart Watch DX Battery Replacement: adım 11, 1 resimden 1.
    • De-solder the red battery wire from the circuit board.
  12. Vtech Kidizoom Smart Watch DX Battery Replacement: adım 12, 1 resimden 1.
    • Repeat the de-soldering for the black (ground) wire.
  13. Vtech Kidizoom Smart Watch DX Battery Replacement: adım 13, 1 resimden 1.
    • Pull the battery free, and wait for the solder to cool before handling further.
Sonuç
4 farklı kişi bu kılavuzu tamamladı.
Navin Ramkishun
259 İtibar
1 Kılavuz yazıldı
Ekip
USF Tampa, Team 10-6, Remmell Spring 2016 USF Tampa, Team 10-6, Remmell Spring 2016 üyesi
USFT-REMMELL-S16S10G6
4 Üyeler
12 adet Kılavuz yazıldı
Bir Yorum
Where did you bought the battery?
funkysoulbrother - Yanıt
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 2
Son 7 gün: 12
Son 30 gün: 57
Her zaman: 9,070
