Ana içeriğe geç
WRS315SDHW Auger Motor Replacement
Neye ihtiyacın var
  1. WRS315SDHW Auger Motor Replacement, Safety precautions: adım 1, 1 resimden 1.
    • Before you begin your repair, perform the following:
    • Turn off your main water supply
    • Unplug your device
  2. WRS315SDHW Auger Motor Replacement, Open the doors: adım 2, 3 resimden 1. WRS315SDHW Auger Motor Replacement, Open the doors: adım 2, 3 resimden 2. WRS315SDHW Auger Motor Replacement, Open the doors: adım 2, 3 resimden 3.
    • Depending on your repair, open one or both doors.
  3. WRS315SDHW Auger Motor Replacement, Remove the icemaker tray: adım 3, 2 resimden 1. WRS315SDHW Auger Motor Replacement, Remove the icemaker tray: adım 3, 2 resimden 2.
    • Pull the icemaker tray completely out of its slot in the chassis.
  4. WRS315SDHW Auger Motor Replacement, Unfasten the icemaker assembly: adım 4, 2 resimden 1. WRS315SDHW Auger Motor Replacement, Unfasten the icemaker assembly: adım 4, 2 resimden 2.
    • Use a 1/4 inch socket wrench to remove the three screws securing the icemaker assembly (shown with the assembly removed):
    • Two 23.9 mm-long screws
    • One 16.7 mm-long screw
  5. WRS315SDHW Auger Motor Replacement, Reposition the icemaker assembly: adım 5, 3 resimden 1. WRS315SDHW Auger Motor Replacement, Reposition the icemaker assembly: adım 5, 3 resimden 2. WRS315SDHW Auger Motor Replacement, Reposition the icemaker assembly: adım 5, 3 resimden 3.
    • Pull the icemaker assembly toward the right edge of the refrigerator to release it from its slot in the chassis.
    • Let the icemaker assembly hang to access its connector.
  6. WRS315SDHW Auger Motor Replacement, Disconnect the icemaker assembly: adım 6, 3 resimden 1. WRS315SDHW Auger Motor Replacement, Disconnect the icemaker assembly: adım 6, 3 resimden 2. WRS315SDHW Auger Motor Replacement, Disconnect the icemaker assembly: adım 6, 3 resimden 3.
    • Disconnect the spade connector attached to the icemaker assembly.
  7. WRS315SDHW Auger Motor Replacement, Remove the icemaker assembly: adım 7, 1 resimden 1.
    • Remove the icemaker assembly.
  8. WRS315SDHW Auger Motor Replacement, Unfasten the icemaker auger assembly: adım 8, 1 resimden 1.
    • Use a 1/4 inch socket wrench to remove the four screws securing the icemaker auger assembly:
    • Two 24.1 mm-long screws
    • Two 16.5 mm-long screws
  9. WRS315SDHW Auger Motor Replacement, Reposition the icemaker auger assembly: adım 9, 3 resimden 1. WRS315SDHW Auger Motor Replacement, Reposition the icemaker auger assembly: adım 9, 3 resimden 2. WRS315SDHW Auger Motor Replacement, Reposition the icemaker auger assembly: adım 9, 3 resimden 3.
    • Pull the icemaker auger assembly off of its slot in the chassis.
    • Let the assembly hang to access its connector.
  10. WRS315SDHW Auger Motor Replacement, Disconnect the icemaker auger assembly: adım 10, 3 resimden 1. WRS315SDHW Auger Motor Replacement, Disconnect the icemaker auger assembly: adım 10, 3 resimden 2. WRS315SDHW Auger Motor Replacement, Disconnect the icemaker auger assembly: adım 10, 3 resimden 3.
    • Use a flathead screwdriver, or a similar tool, to compress the connector attached to the icemaker auger assembly.
    • Use your hands to disconnect the assembly connector.
  11. WRS315SDHW Auger Motor Replacement, Remove the icemaker auger assembly: adım 11, 1 resimden 1.
    • Remove the icemaker auger assembly.
  12. WRS315SDHW Auger Motor Replacement, Remove the auger fin: adım 12, 3 resimden 1. WRS315SDHW Auger Motor Replacement, Remove the auger fin: adım 12, 3 resimden 2. WRS315SDHW Auger Motor Replacement, Remove the auger fin: adım 12, 3 resimden 3.
    • Twist the auger fin clockwise until it separates from the assembly.
    • Remove the auger fin.
  13. WRS315SDHW Auger Motor Replacement, Unfasten the grounding wire: adım 13, 1 resimden 1.
    • Use a 1/4 inch socket wrench, or a flathead screwdriver, to remove the 11.6 mm-long screw securing the grounding wire.
  14. WRS315SDHW Auger Motor Replacement, Unfasten the auger motor: adım 14, 1 resimden 1.
    • Use a 1/4 inch socket wrench to remove the three 16.7 mm-long screws securing the auger motor.
  15. WRS315SDHW Auger Motor Replacement, Disconnect the auger motor: adım 15, 2 resimden 1. WRS315SDHW Auger Motor Replacement, Disconnect the auger motor: adım 15, 2 resimden 2.
    • Use needle nose pliers, or your hands, to disconnect the grounding wire from the auger motor.
  16. WRS315SDHW Auger Motor Replacement: adım 16, 3 resimden 1. WRS315SDHW Auger Motor Replacement: adım 16, 3 resimden 2. WRS315SDHW Auger Motor Replacement: adım 16, 3 resimden 3.
    • Disconnect the two spade connectors attached to the auger motor.
  17. WRS315SDHW Auger Motor Replacement, Only the auger motor remains: adım 17, 1 resimden 1.
    • You're now left with the auger motor.
Sonuç
Repair didn’t go as planned? Ask our Answers community for help.
Bir başkası bu kılavuzu tamamladı.
nicO
15.927 İtibar
89 adet Kılavuz yazıldı
Ekip
Global Fixers Global Fixers üyesi
Community
45 Üyeler
706 adet Kılavuz yazıldı
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 4
Son 30 gün: 9
Her zaman: 164
