Ana içeriğe geç
WRS315SDHW Condenser Fan Replacement
Neye ihtiyacın var
  1. WRS315SDHW Condenser Fan Replacement, Safety precautions: adım 1, 1 resimden 1.
    • Before you begin your repair, perform the following:
    • Turn off your main water supply
    • Unplug your device
  2. WRS315SDHW Condenser Fan Replacement, Unfasten the rear panel: adım 2, 3 resimden 1. WRS315SDHW Condenser Fan Replacement, Unfasten the rear panel: adım 2, 3 resimden 2. WRS315SDHW Condenser Fan Replacement, Unfasten the rear panel: adım 2, 3 resimden 3.
    • Use a 1/4 inch socket wrench, or a flathead screwdriver, to remove the seven 16.2 mm-long screws securing the rear panel.
    • Use a 1/4 inch socket wrench to loosen the screw securing the water hose enough for the rear panel to freely move.
  3. WRS315SDHW Condenser Fan Replacement, Remove the rear panel: adım 3, 3 resimden 1. WRS315SDHW Condenser Fan Replacement, Remove the rear panel: adım 3, 3 resimden 2. WRS315SDHW Condenser Fan Replacement, Remove the rear panel: adım 3, 3 resimden 3.
    • Pull the rear panel off the chassis to remove it.
  4. WRS315SDHW Condenser Fan Replacement, Disconnect the condenser fan: adım 4, 2 resimden 1. WRS315SDHW Condenser Fan Replacement, Disconnect the condenser fan: adım 4, 2 resimden 2.
    • Press the tab on the condenser fan cable connector to unclip it.
    • Pull the connector straight out of its slot to remove it.
  5. WRS315SDHW Condenser Fan Replacement, Remove the condenser fan: adım 5, 3 resimden 1. WRS315SDHW Condenser Fan Replacement, Remove the condenser fan: adım 5, 3 resimden 2. WRS315SDHW Condenser Fan Replacement, Remove the condenser fan: adım 5, 3 resimden 3.
    • Put on gloves before continuing, as the sheet metal and the fan itself are sharp.
    • Pull the condenser fan straight off its peg to remove it.
  6. WRS315SDHW Condenser Fan Replacement, Unfasten the condenser fan motor: adım 6, 1 resimden 1.
    • Use a 1/4 inch socket wrench to remove the four 16.5 mm-long screws securing the condenser fan motor to the chassis.
  7. WRS315SDHW Condenser Fan Replacement, Remove the motor: adım 7, 3 resimden 1. WRS315SDHW Condenser Fan Replacement, Remove the motor: adım 7, 3 resimden 2. WRS315SDHW Condenser Fan Replacement, Remove the motor: adım 7, 3 resimden 3.
    • Rotate the motor housing through its slot in the chassis.
    • Remove the motor.
Sonuç
Repair didn’t go as planned? Ask our Answers community for help.
Bir başkası bu kılavuzu tamamladı.
nicO
15.927 İtibar
89 adet Kılavuz yazıldı
Ekip
Global Fixers Global Fixers üyesi
Community
45 Üyeler
705 adet Kılavuz yazıldı
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 1
Son 7 gün: 3
Son 30 gün: 4
Her zaman: 137
