Ana içeriğe geç
WRS315SDHW Control Board Replacement
Neye ihtiyacın var
  1. WRS315SDHW Control Board Replacement, Safety precautions: adım 1, 1 resimden 1.
    • Before you begin your repair, perform the following:
    • Turn off your main water supply
    • Unplug your device
  2. WRS315SDHW Control Board Replacement, Unfasten the dispenser panels: adım 2, 2 resimden 1. WRS315SDHW Control Board Replacement, Unfasten the dispenser panels: adım 2, 2 resimden 2.
    • The dispenser panel screws are located under the dispenser as if you're looking up into the dispenser tube (where the ice cubes and water come out).
    • Use a 1/4 inch socket wrench to remove the two 15.6 mm-long screws securing the two dispenser panels.
  3. WRS315SDHW Control Board Replacement, Remove the dispenser panels: adım 3, 3 resimden 1. WRS315SDHW Control Board Replacement, Remove the dispenser panels: adım 3, 3 resimden 2. WRS315SDHW Control Board Replacement, Remove the dispenser panels: adım 3, 3 resimden 3.
    • Pull the dispenser panels straight down to separate them from the chassis.
    • Remove the dispenser panels.
  4. WRS315SDHW Control Board Replacement, Unfasten the control board: adım 4, 1 resimden 1.
    • Use a 1/4 inch socket wrench to remove the two 15.6 mm-long screws securing the control board.
  5. WRS315SDHW Control Board Replacement: adım 5, 3 resimden 1. WRS315SDHW Control Board Replacement: adım 5, 3 resimden 2. WRS315SDHW Control Board Replacement: adım 5, 3 resimden 3.
    • Tilt the bottom of the control board away from the chassis to release its clips.
    • Pull straight down to separate the control board enough to access its connectors.
  6. WRS315SDHW Control Board Replacement, Disconnect the control board: adım 6, 3 resimden 1. WRS315SDHW Control Board Replacement, Disconnect the control board: adım 6, 3 resimden 2. WRS315SDHW Control Board Replacement, Disconnect the control board: adım 6, 3 resimden 3.
    • Disconnect the large connector attached to the right edge of the control board.
  7. WRS315SDHW Control Board Replacement: adım 7, 2 resimden 1. WRS315SDHW Control Board Replacement: adım 7, 2 resimden 2.
    • Disconnect the small connector attached to the left edge of the control board.
  8. WRS315SDHW Control Board Replacement, Remove the control board: adım 8, 1 resimden 1.
    • Remove the control board.
Sonuç
Repair didn’t go as planned? Ask our Answers community for help.
Bir başkası bu kılavuzu tamamladı.
nicO
15.927 İtibar
89 adet Kılavuz yazıldı
Ekip
Global Fixers Global Fixers üyesi
Community
45 Üyeler
704 adet Kılavuz yazıldı
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 1
Son 7 gün: 4
Son 30 gün: 37
Her zaman: 406
