Ana içeriğe geç
WRS315SDHW Defrost Thermistor Replacement
Neye ihtiyacın var
  1. WRS315SDHW Defrost Thermistor Replacement, Safety precautions: adım 1, 1 resimden 1.
    • Before you begin your repair, perform the following:
    • Turn off your main water supply
    • Unplug your device
  2. WRS315SDHW Defrost Thermistor Replacement, Open the doors: adım 2, 3 resimden 1. WRS315SDHW Defrost Thermistor Replacement, Open the doors: adım 2, 3 resimden 2. WRS315SDHW Defrost Thermistor Replacement, Open the doors: adım 2, 3 resimden 3.
    • Depending on your repair, open one or both doors.
  3. WRS315SDHW Defrost Thermistor Replacement, Remove the drawers: adım 3, 2 resimden 1. WRS315SDHW Defrost Thermistor Replacement, Remove the drawers: adım 3, 2 resimden 2.
    • Remove the drawers and shelves from the freezer section.
  4. WRS315SDHW Defrost Thermistor Replacement: adım 4, 2 resimden 1. WRS315SDHW Defrost Thermistor Replacement: adım 4, 2 resimden 2.
    • Remove the screw(s) securing the evaporator cover.
  5. WRS315SDHW Defrost Thermistor Replacement, Unclip the evaporator cover: adım 5, 3 resimden 1. WRS315SDHW Defrost Thermistor Replacement, Unclip the evaporator cover: adım 5, 3 resimden 2. WRS315SDHW Defrost Thermistor Replacement, Unclip the evaporator cover: adım 5, 3 resimden 3.
    • Lift the bottom of the evaporator cover up and over its lip in the chassis.
    • Pull the cover toward yourself to release its top clips.
  6. WRS315SDHW Defrost Thermistor Replacement, Remove the evaporator cover: adım 6, 3 resimden 1. WRS315SDHW Defrost Thermistor Replacement, Remove the evaporator cover: adım 6, 3 resimden 2. WRS315SDHW Defrost Thermistor Replacement, Remove the evaporator cover: adım 6, 3 resimden 3.
    • Continue pulling the evaporator cover towards yourself to unclip its metal prongs from the chassis.
    • Remove the evaporator cover.
  7. WRS315SDHW Defrost Thermistor Replacement, Unclip the thermistor: adım 7, 3 resimden 1. WRS315SDHW Defrost Thermistor Replacement, Unclip the thermistor: adım 7, 3 resimden 2. WRS315SDHW Defrost Thermistor Replacement, Unclip the thermistor: adım 7, 3 resimden 3.
    • Use a spudger to push the tip of the thermistor through its slot in the wire harness.
  8. WRS315SDHW Defrost Thermistor Replacement, Disconnect the thermistor: adım 8, 2 resimden 1. WRS315SDHW Defrost Thermistor Replacement, Disconnect the thermistor: adım 8, 2 resimden 2.
    • Disconnect the thermistor from the wiring harness.
  9. WRS315SDHW Defrost Thermistor Replacement, Remove the thermistor: adım 9, 1 resimden 1.
    • Remove the thermistor.
Sonuç
Repair didn’t go as planned? Ask our Answers community for help.
Bir başkası bu kılavuzu tamamladı.
nicO
15.927 İtibar
89 adet Kılavuz yazıldı
Ekip
Global Fixers Global Fixers üyesi
Community
45 Üyeler
704 adet Kılavuz yazıldı
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 1
Son 7 gün: 1
Son 30 gün: 7
Her zaman: 205
