Ana içeriğe geç
WRS315SDHW Dispenser Solenoid Replacement
Neye ihtiyacın var
  1. WRS315SDHW Dispenser Solenoid Replacement, Safety precautions: adım 1, 1 resimden 1.
    • Before you begin your repair, perform the following:
    • Turn off your main water supply
    • Unplug your device
  2. WRS315SDHW Dispenser Solenoid Replacement, Open the doors: adım 2, 3 resimden 1. WRS315SDHW Dispenser Solenoid Replacement, Open the doors: adım 2, 3 resimden 2. WRS315SDHW Dispenser Solenoid Replacement, Open the doors: adım 2, 3 resimden 3.
    • Depending on your repair, open one or both doors.
  3. WRS315SDHW Dispenser Solenoid Replacement, Remove the icemaker tray: adım 3, 2 resimden 1. WRS315SDHW Dispenser Solenoid Replacement, Remove the icemaker tray: adım 3, 2 resimden 2.
    • Pull the icemaker tray completely out of its slot in the chassis.
  4. WRS315SDHW Dispenser Solenoid Replacement, Unfasten the icemaker assembly: adım 4, 2 resimden 1. WRS315SDHW Dispenser Solenoid Replacement, Unfasten the icemaker assembly: adım 4, 2 resimden 2.
    • Use a 1/4 inch socket wrench to remove the three screws securing the icemaker assembly (shown with the assembly removed):
    • Two 23.9 mm-long screws
    • One 16.7 mm-long screw
  5. WRS315SDHW Dispenser Solenoid Replacement, Reposition the icemaker assembly: adım 5, 3 resimden 1. WRS315SDHW Dispenser Solenoid Replacement, Reposition the icemaker assembly: adım 5, 3 resimden 2. WRS315SDHW Dispenser Solenoid Replacement, Reposition the icemaker assembly: adım 5, 3 resimden 3.
    • Pull the icemaker assembly toward the right edge of the refrigerator to release it from its slot in the chassis.
    • Let the icemaker assembly hang to access its connector.
  6. WRS315SDHW Dispenser Solenoid Replacement, Disconnect the icemaker assembly: adım 6, 3 resimden 1. WRS315SDHW Dispenser Solenoid Replacement, Disconnect the icemaker assembly: adım 6, 3 resimden 2. WRS315SDHW Dispenser Solenoid Replacement, Disconnect the icemaker assembly: adım 6, 3 resimden 3.
    • Disconnect the spade connector attached to the icemaker assembly.
  7. WRS315SDHW Dispenser Solenoid Replacement, Remove the icemaker assembly: adım 7, 1 resimden 1.
    • Remove the icemaker assembly.
  8. WRS315SDHW Dispenser Solenoid Replacement, Unfasten the icemaker auger assembly: adım 8, 1 resimden 1.
    • Use a 1/4 inch socket wrench to remove the four screws securing the icemaker auger assembly:
    • Two 24.1 mm-long screws
    • Two 16.5 mm-long screws
  9. WRS315SDHW Dispenser Solenoid Replacement, Reposition the icemaker auger assembly: adım 9, 3 resimden 1. WRS315SDHW Dispenser Solenoid Replacement, Reposition the icemaker auger assembly: adım 9, 3 resimden 2. WRS315SDHW Dispenser Solenoid Replacement, Reposition the icemaker auger assembly: adım 9, 3 resimden 3.
    • Pull the icemaker auger assembly off of its slot in the chassis.
    • Let the assembly hang to access its connector.
  10. WRS315SDHW Dispenser Solenoid Replacement, Disconnect the icemaker auger assembly: adım 10, 3 resimden 1. WRS315SDHW Dispenser Solenoid Replacement, Disconnect the icemaker auger assembly: adım 10, 3 resimden 2. WRS315SDHW Dispenser Solenoid Replacement, Disconnect the icemaker auger assembly: adım 10, 3 resimden 3.
    • Use a flathead screwdriver, or a similar tool, to compress the connector attached to the icemaker auger assembly.
    • Use your hands to disconnect the assembly connector.
  11. WRS315SDHW Dispenser Solenoid Replacement, Remove the icemaker auger assembly: adım 11, 1 resimden 1.
    • Remove the icemaker auger assembly.
  12. WRS315SDHW Dispenser Solenoid Replacement, Remove the dispenser: adım 12, 3 resimden 1. WRS315SDHW Dispenser Solenoid Replacement, Remove the dispenser: adım 12, 3 resimden 2. WRS315SDHW Dispenser Solenoid Replacement, Remove the dispenser: adım 12, 3 resimden 3.
    • Slide the dispenser head out of its slot in the icemaker auger assembly.
  13. WRS315SDHW Dispenser Solenoid Replacement: adım 13, 2 resimden 1. WRS315SDHW Dispenser Solenoid Replacement: adım 13, 2 resimden 2.
    • Remove the dispenser head out of its metal solenoid cube.
  14. WRS315SDHW Dispenser Solenoid Replacement, Remove the tape: adım 14, 3 resimden 1. WRS315SDHW Dispenser Solenoid Replacement, Remove the tape: adım 14, 3 resimden 2. WRS315SDHW Dispenser Solenoid Replacement, Remove the tape: adım 14, 3 resimden 3.
    • Peel the tape off the solenoid connector.
    • Set the tape aside. You'll reuse it during reassembly.
  15. WRS315SDHW Dispenser Solenoid Replacement, Disconnect the solenoid: adım 15, 3 resimden 1. WRS315SDHW Dispenser Solenoid Replacement, Disconnect the solenoid: adım 15, 3 resimden 2. WRS315SDHW Dispenser Solenoid Replacement, Disconnect the solenoid: adım 15, 3 resimden 3.
    • Pull the solenoid spade connector straight out of the solenoid to disconnect it.
Sonuç
Repair didn’t go as planned? Ask our Answers community for help.
nicO
15.927 İtibar
89 adet Kılavuz yazıldı
Ekip
Global Fixers Global Fixers üyesi
Community
45 Üyeler
704 adet Kılavuz yazıldı
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 0
Son 30 gün: 3
Her zaman: 98
