Ana içeriğe geç
WRS315SDHW Door Light Replacement
Neye ihtiyacın var
  1. WRS315SDHW Door Light Replacement, Open the doors: adım 1, 3 resimden 1. WRS315SDHW Door Light Replacement, Open the doors: adım 1, 3 resimden 2. WRS315SDHW Door Light Replacement, Open the doors: adım 1, 3 resimden 3.
    • Depending on your repair, open one or both doors.
  2. WRS315SDHW Door Light Replacement, Unclip the door light: adım 2, 2 resimden 1. WRS315SDHW Door Light Replacement, Unclip the door light: adım 2, 2 resimden 2.
    • Be careful during this step, as it's easy to scratch the interior of the fridge or crack cold and brittle plastic.
    • Carefully insert a flathead screwdriver, or a similar tool, between the door light and the chassis.
    • Pry up to separate the door light enough so you can grip it with your fingers.
  3. WRS315SDHW Door Light Replacement: adım 3, 3 resimden 1. WRS315SDHW Door Light Replacement: adım 3, 3 resimden 2. WRS315SDHW Door Light Replacement: adım 3, 3 resimden 3.
    • Tilt the door light toward the right edge of the refrigerator to completely release its plastic clips.
    • Pull the light down to expose its connectors.
  4. WRS315SDHW Door Light Replacement: adım 4, 3 resimden 1. WRS315SDHW Door Light Replacement: adım 4, 3 resimden 2. WRS315SDHW Door Light Replacement: adım 4, 3 resimden 3.
    • Disconnect the two spade connectors attached to the door light.
    • Remove the door light.
Sonuç
Repair didn’t go as planned? Ask our Answers community for help.
Bir başkası bu kılavuzu tamamladı.
nicO
15.927 İtibar
89 adet Kılavuz yazıldı
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 1
Son 7 gün: 2
Son 30 gün: 6
Her zaman: 125
