Ana içeriğe geç
WRS315SDHW Freezer Door Replacement
Neye ihtiyacın var
  1. WRS315SDHW Freezer Door Replacement, Safety precautions: adım 1, 1 resimden 1.
    • Before you begin your repair, perform the following:
    • Turn off your main water supply
    • Unplug your device
  2. WRS315SDHW Freezer Door Replacement, Open the doors: adım 2, 3 resimden 1. WRS315SDHW Freezer Door Replacement, Open the doors: adım 2, 3 resimden 2. WRS315SDHW Freezer Door Replacement, Open the doors: adım 2, 3 resimden 3.
    • Depending on your repair, open one or both doors.
  3. WRS315SDHW Freezer Door Replacement, Unfasten the front panel: adım 3, 3 resimden 1. WRS315SDHW Freezer Door Replacement, Unfasten the front panel: adım 3, 3 resimden 2. WRS315SDHW Freezer Door Replacement, Unfasten the front panel: adım 3, 3 resimden 3.
    • Use a Phillips driver to remove the two 15.2 mm-long screws securing the front panel.
  4. WRS315SDHW Freezer Door Replacement, Remove the front panel: adım 4, 3 resimden 1. WRS315SDHW Freezer Door Replacement, Remove the front panel: adım 4, 3 resimden 2. WRS315SDHW Freezer Door Replacement, Remove the front panel: adım 4, 3 resimden 3.
    • Pull the front panel straight off the chassis and remove it.
    • You may have to slightly open the water filter door to remove the front panel completely.
  5. WRS315SDHW Freezer Door Replacement, Unfasten the door connections: adım 5, 2 resimden 1. WRS315SDHW Freezer Door Replacement, Unfasten the door connections: adım 5, 2 resimden 2.
    • Use a 1/4 inch socket wrench to remove the 16.7 mm-long screw securing the freezer door wiring harness.
    • Use a 1/4 inch socket wrench to remove the 16.2 mm-long screw securing the freezer door water hose.
  6. WRS315SDHW Freezer Door Replacement, Reposition the wiring harness: adım 6, 2 resimden 1. WRS315SDHW Freezer Door Replacement, Reposition the wiring harness: adım 6, 2 resimden 2.
    • Pull the wiring harness out of its slot in the chassis to access its connectors.
  7. WRS315SDHW Freezer Door Replacement, Disconnect the wiring harness: adım 7, 3 resimden 1. WRS315SDHW Freezer Door Replacement, Disconnect the wiring harness: adım 7, 3 resimden 2. WRS315SDHW Freezer Door Replacement, Disconnect the wiring harness: adım 7, 3 resimden 3.
    • Disconnect the two connectors attached to the door wiring harness.
  8. WRS315SDHW Freezer Door Replacement: adım 8, 1 resimden 1.
    • Place a clean cloth under the water hose before continuing.
  9. WRS315SDHW Freezer Door Replacement: adım 9, 2 resimden 1. WRS315SDHW Freezer Door Replacement: adım 9, 2 resimden 2.
    • Pull the plastic clip off the freezer door water hose.
  10. WRS315SDHW Freezer Door Replacement, Disconnect the water hose: adım 10, 3 resimden 1. WRS315SDHW Freezer Door Replacement, Disconnect the water hose: adım 10, 3 resimden 2. WRS315SDHW Freezer Door Replacement, Disconnect the water hose: adım 10, 3 resimden 3.
    • Use one hand to compress the blue plastic ring into the green section of the hose.
    • Use the other hand to pull the white water tube out of its slot.
  11. WRS315SDHW Freezer Door Replacement, Unfasten the freezer door: adım 11, 2 resimden 1. WRS315SDHW Freezer Door Replacement, Unfasten the freezer door: adım 11, 2 resimden 2.
    • Hold the door while performing the next two steps to avoid the door from accidentally falling.
    • Use a 3/16 inch Allen wrench to remove the two 19.3 mm-long screws securing the freezer door.
    • The Torx screws are for alignment and don't need to be removed.
  12. WRS315SDHW Freezer Door Replacement, Remove the door hinge: adım 12, 3 resimden 1. WRS315SDHW Freezer Door Replacement, Remove the door hinge: adım 12, 3 resimden 2. WRS315SDHW Freezer Door Replacement, Remove the door hinge: adım 12, 3 resimden 3.
    • Pull the door hinge straight up to separate its alignment pins from the chassis.
    • Remove the door hinge.
  13. WRS315SDHW Freezer Door Replacement, Reposition the cables: adım 13, 3 resimden 1. WRS315SDHW Freezer Door Replacement, Reposition the cables: adım 13, 3 resimden 2. WRS315SDHW Freezer Door Replacement, Reposition the cables: adım 13, 3 resimden 3.
    • Pull the freezer door straight up to disconnect it from the chassis.
    • Thread the cables through their slot in the chassis.
    • You may need to thread them individually.
  14. WRS315SDHW Freezer Door Replacement, Remove the door: adım 14, 2 resimden 1. WRS315SDHW Freezer Door Replacement, Remove the door: adım 14, 2 resimden 2.
    • You're now left with the freezer door.
Sonuç
Repair didn’t go as planned? Ask our Answers community for help.
Bir başkası bu kılavuzu tamamladı.
nicO
15.927 İtibar
89 adet Kılavuz yazıldı
Ekip
Global Fixers Global Fixers üyesi
Community
45 Üyeler
704 adet Kılavuz yazıldı
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 1
Son 30 gün: 1
Her zaman: 101
