Ana içeriğe geç
WRS315SDHW Icemaker Assembly Replacement
Neye ihtiyacın var
  1. WRS315SDHW Icemaker Assembly Replacement, Safety precautions: adım 1, 1 resimden 1.
    • Before you begin your repair, perform the following:
    • Turn off your main water supply
    • Unplug your device
  2. WRS315SDHW Icemaker Assembly Replacement, Open the doors: adım 2, 3 resimden 1. WRS315SDHW Icemaker Assembly Replacement, Open the doors: adım 2, 3 resimden 2. WRS315SDHW Icemaker Assembly Replacement, Open the doors: adım 2, 3 resimden 3.
    • Depending on your repair, open one or both doors.
  3. WRS315SDHW Icemaker Assembly Replacement, Remove the icemaker tray: adım 3, 2 resimden 1. WRS315SDHW Icemaker Assembly Replacement, Remove the icemaker tray: adım 3, 2 resimden 2.
    • Pull the icemaker tray completely out of its slot in the chassis.
  4. WRS315SDHW Icemaker Assembly Replacement, Unfasten the icemaker assembly: adım 4, 2 resimden 1. WRS315SDHW Icemaker Assembly Replacement, Unfasten the icemaker assembly: adım 4, 2 resimden 2.
    • Use a 1/4 inch socket wrench to remove the three screws securing the icemaker assembly (shown with the assembly removed):
    • Two 23.9 mm-long screws
    • One 16.7 mm-long screw
  5. WRS315SDHW Icemaker Assembly Replacement, Reposition the icemaker assembly: adım 5, 3 resimden 1. WRS315SDHW Icemaker Assembly Replacement, Reposition the icemaker assembly: adım 5, 3 resimden 2. WRS315SDHW Icemaker Assembly Replacement, Reposition the icemaker assembly: adım 5, 3 resimden 3.
    • Pull the icemaker assembly toward the right edge of the refrigerator to release it from its slot in the chassis.
    • Let the icemaker assembly hang to access its connector.
  6. WRS315SDHW Icemaker Assembly Replacement, Disconnect the icemaker assembly: adım 6, 3 resimden 1. WRS315SDHW Icemaker Assembly Replacement, Disconnect the icemaker assembly: adım 6, 3 resimden 2. WRS315SDHW Icemaker Assembly Replacement, Disconnect the icemaker assembly: adım 6, 3 resimden 3.
    • Disconnect the spade connector attached to the icemaker assembly.
  7. WRS315SDHW Icemaker Assembly Replacement, Remove the icemaker assembly: adım 7, 1 resimden 1.
    • Remove the icemaker assembly.
Sonuç
Repair didn’t go as planned? Ask our Answers community for help.
Bir başkası bu kılavuzu tamamladı.
nicO
15.927 İtibar
89 adet Kılavuz yazıldı
Ekip
Global Fixers Global Fixers üyesi
Community
45 Üyeler
707 adet Kılavuz yazıldı
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 2
Son 30 gün: 12
Her zaman: 313
