Ana içeriğe geç
WRS315SDHW Inlet Valve Assembly Replacement
Neye ihtiyacın var
  1. WRS315SDHW Inlet Valve Assembly Replacement, Safety precautions: adım 1, 1 resimden 1.
    • Before you begin your repair, perform the following:
    • Turn off your main water supply
    • Unplug your device
  2. WRS315SDHW Inlet Valve Assembly Replacement, Unfasten the rear panel: adım 2, 3 resimden 1. WRS315SDHW Inlet Valve Assembly Replacement, Unfasten the rear panel: adım 2, 3 resimden 2. WRS315SDHW Inlet Valve Assembly Replacement, Unfasten the rear panel: adım 2, 3 resimden 3.
    • Use a 1/4 inch socket wrench, or a flathead screwdriver, to remove the seven 16.2 mm-long screws securing the rear panel.
    • Use a 1/4 inch socket wrench to loosen the screw securing the water hose enough for the rear panel to freely move.
  3. WRS315SDHW Inlet Valve Assembly Replacement, Remove the rear panel: adım 3, 3 resimden 1. WRS315SDHW Inlet Valve Assembly Replacement, Remove the rear panel: adım 3, 3 resimden 2. WRS315SDHW Inlet Valve Assembly Replacement, Remove the rear panel: adım 3, 3 resimden 3.
    • Pull the rear panel off the chassis to remove it.
  4. WRS315SDHW Inlet Valve Assembly Replacement, Remove the clip: adım 4, 2 resimden 1. WRS315SDHW Inlet Valve Assembly Replacement, Remove the clip: adım 4, 2 resimden 2.
    • Use needle nose pliers, or your fingers, to remove the plastic clip on the inlet valve assembly.
  5. WRS315SDHW Inlet Valve Assembly Replacement, Disconnect the front water hose: adım 5, 3 resimden 1. WRS315SDHW Inlet Valve Assembly Replacement, Disconnect the front water hose: adım 5, 3 resimden 2. WRS315SDHW Inlet Valve Assembly Replacement, Disconnect the front water hose: adım 5, 3 resimden 3.
    • Push the plastic ring above the front water hose to release its clips.
    • As you push the ring, pull the water hose downward to disconnect it.
    • Repeat the disconnection procedure for the other water hose on the inlet valve assembly.
  6. WRS315SDHW Inlet Valve Assembly Replacement, Unfasten the inlet valve assembly: adım 6, 1 resimden 1.
    • Use a 1/4 inch socket wrench to remove the two 15.6 mm-long screws securing the inlet valve assembly.
  7. WRS315SDHW Inlet Valve Assembly Replacement, Reposition the inlet valve assembly: adım 7, 3 resimden 1. WRS315SDHW Inlet Valve Assembly Replacement, Reposition the inlet valve assembly: adım 7, 3 resimden 2. WRS315SDHW Inlet Valve Assembly Replacement, Reposition the inlet valve assembly: adım 7, 3 resimden 3.
    • Pull the inlet valve assembly off its slot in the chassis and rest it on the floor.
  8. WRS315SDHW Inlet Valve Assembly Replacement: adım 8, 2 resimden 1. WRS315SDHW Inlet Valve Assembly Replacement: adım 8, 2 resimden 2.
    • Place a clean and dry rag under the inlet valve assembly before continuing.
  9. WRS315SDHW Inlet Valve Assembly Replacement, Remove the clip: adım 9, 2 resimden 1. WRS315SDHW Inlet Valve Assembly Replacement, Remove the clip: adım 9, 2 resimden 2.
    • Use needle nose pliers, or your hands, to pull the blue clip off the rear water hose.
  10. WRS315SDHW Inlet Valve Assembly Replacement: adım 10, 3 resimden 1. WRS315SDHW Inlet Valve Assembly Replacement: adım 10, 3 resimden 2. WRS315SDHW Inlet Valve Assembly Replacement: adım 10, 3 resimden 3.
    • Push the yellow plastic ring above the rear water hose to release its clips.
    • As you push the ring, pull the water hose away from the inlet valve assembly to disconnect it.
  11. WRS315SDHW Inlet Valve Assembly Replacement, Disconnect the assembly wire connector: adım 11, 3 resimden 1. WRS315SDHW Inlet Valve Assembly Replacement, Disconnect the assembly wire connector: adım 11, 3 resimden 2. WRS315SDHW Inlet Valve Assembly Replacement, Disconnect the assembly wire connector: adım 11, 3 resimden 3.
    • Use a flathead screwdriver, or a similar tool, to disconnect the inlet valve assembly wire connector.
  12. WRS315SDHW Inlet Valve Assembly Replacement, Remove the inlet valve assembly: adım 12, 1 resimden 1.
    • Remove the inlet valve assembly from the chassis.
Sonuç
Repair didn’t go as planned? Ask our Answers community for help.
Bir başkası bu kılavuzu tamamladı.
nicO
15.927 İtibar
89 adet Kılavuz yazıldı
Ekip
Global Fixers Global Fixers üyesi
Community
45 Üyeler
704 adet Kılavuz yazıldı
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 0
Son 30 gün: 1
Her zaman: 181
