Ana içeriğe geç
WRS315SDHW Refrigerator Thermistor Replacement
Neye ihtiyacın var
  1. WRS315SDHW Refrigerator Thermistor Replacement, Safety precautions: adım 1, 1 resimden 1.
    • Before you begin your repair, perform the following:
    • Turn off your main water supply
    • Unplug your device
  2. WRS315SDHW Refrigerator Thermistor Replacement, Open the doors: adım 2, 3 resimden 1. WRS315SDHW Refrigerator Thermistor Replacement, Open the doors: adım 2, 3 resimden 2. WRS315SDHW Refrigerator Thermistor Replacement, Open the doors: adım 2, 3 resimden 3.
    • Depending on your repair, open one or both doors.
  3. WRS315SDHW Refrigerator Thermistor Replacement, Unfasten the temperature control board assembly: adım 3, 2 resimden 1. WRS315SDHW Refrigerator Thermistor Replacement, Unfasten the temperature control board assembly: adım 3, 2 resimden 2.
    • Use a 1/4 inch socket wrench, or a flathead screwdriver, to remove the 22.3 mm-long screw securing the temperature control board assembly (shown with the assembly removed).
  4. WRS315SDHW Refrigerator Thermistor Replacement, Reposition the assembly: adım 4, 3 resimden 1. WRS315SDHW Refrigerator Thermistor Replacement, Reposition the assembly: adım 4, 3 resimden 2. WRS315SDHW Refrigerator Thermistor Replacement, Reposition the assembly: adım 4, 3 resimden 3.
    • Pull the temperature control board assembly off its slot in the chassis.
    • Let the assembly hang to access its connectors.
  5. WRS315SDHW Refrigerator Thermistor Replacement, Disconnect the temperature control board: adım 5, 3 resimden 1. WRS315SDHW Refrigerator Thermistor Replacement, Disconnect the temperature control board: adım 5, 3 resimden 2. WRS315SDHW Refrigerator Thermistor Replacement, Disconnect the temperature control board: adım 5, 3 resimden 3.
    • Disconnect the two harness connectors attached to the temperature control board assembly.
  6. WRS315SDHW Refrigerator Thermistor Replacement, Remove the assembly: adım 6, 1 resimden 1.
    • Remove the temperature control board assembly.
  7. WRS315SDHW Refrigerator Thermistor Replacement, Disconnect the thermistor: adım 7, 3 resimden 1. WRS315SDHW Refrigerator Thermistor Replacement, Disconnect the thermistor: adım 7, 3 resimden 2. WRS315SDHW Refrigerator Thermistor Replacement, Disconnect the thermistor: adım 7, 3 resimden 3.
    • Pinch and pull the connector attached to the thermistor to disconnect it.
  8. WRS315SDHW Refrigerator Thermistor Replacement, Remove the thermistor: adım 8, 2 resimden 1. WRS315SDHW Refrigerator Thermistor Replacement, Remove the thermistor: adım 8, 2 resimden 2.
    • Use a flathead screwdriver, or a similar tool, to pry up the thermistor from its slot in the chassis.
    • Remove the thermistor.
Sonuç
Repair didn’t go as planned? Ask our Answers community for help.
Bir başkası bu kılavuzu tamamladı.
nicO
15.927 İtibar
89 adet Kılavuz yazıldı
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 6
Son 30 gün: 11
Her zaman: 343
