Ana içeriğe geç
WRS315SDHW Start Relay Assembly Replacement
Neye ihtiyacın var
  1. WRS315SDHW Start Relay Assembly Replacement, Safety precautions: adım 1, 1 resimden 1.
    • Before you begin your repair, perform the following:
    • Turn off your main water supply
    • Unplug your device
  2. WRS315SDHW Start Relay Assembly Replacement, Unfasten the rear panel: adım 2, 3 resimden 1. WRS315SDHW Start Relay Assembly Replacement, Unfasten the rear panel: adım 2, 3 resimden 2. WRS315SDHW Start Relay Assembly Replacement, Unfasten the rear panel: adım 2, 3 resimden 3.
    • Use a 1/4 inch socket wrench, or a flathead screwdriver, to remove the seven 16.2 mm-long screws securing the rear panel.
    • Use a 1/4 inch socket wrench to loosen the screw securing the water hose enough for the rear panel to freely move.
  3. WRS315SDHW Start Relay Assembly Replacement, Remove the rear panel: adım 3, 3 resimden 1. WRS315SDHW Start Relay Assembly Replacement, Remove the rear panel: adım 3, 3 resimden 2. WRS315SDHW Start Relay Assembly Replacement, Remove the rear panel: adım 3, 3 resimden 3.
    • Pull the rear panel off the chassis to remove it.
  4. WRS315SDHW Start Relay Assembly Replacement, Disconnect the start relay assembly: adım 4, 3 resimden 1. WRS315SDHW Start Relay Assembly Replacement, Disconnect the start relay assembly: adım 4, 3 resimden 2. WRS315SDHW Start Relay Assembly Replacement, Disconnect the start relay assembly: adım 4, 3 resimden 3.
    • Use a flathead screwdriver, or a similar tool, to disconnect the connector attached to the start relay assembly.
  5. WRS315SDHW Start Relay Assembly Replacement, Unclip the start relay assembly: adım 5, 3 resimden 1. WRS315SDHW Start Relay Assembly Replacement, Unclip the start relay assembly: adım 5, 3 resimden 2. WRS315SDHW Start Relay Assembly Replacement, Unclip the start relay assembly: adım 5, 3 resimden 3.
    • Pull the metal clip out its hole in the top of the start relay assembly.
    • Rest the clip next to the assembly.
  6. WRS315SDHW Start Relay Assembly Replacement, Remove the start relay assembly: adım 6, 3 resimden 1. WRS315SDHW Start Relay Assembly Replacement, Remove the start relay assembly: adım 6, 3 resimden 2. WRS315SDHW Start Relay Assembly Replacement, Remove the start relay assembly: adım 6, 3 resimden 3.
    • Pull the start relay assembly straight off its prongs in the chassis.
    • Remove the start relay assembly.
    • The assembly consists of the start capacitor, start relay, and overload relay.
Sonuç
Repair didn’t go as planned? Ask our Answers community for help.
nicO
15.927 İtibar
89 adet Kılavuz yazıldı
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 2
Son 30 gün: 6
Her zaman: 124
