Ana içeriğe geç
Wacom Intuos CTL4100 Battery Replacement
Neye ihtiyacın var
  1. Wacom Intuos CTL4100 Battery Replacement, Battery: adım 1, 3 resimden 1. Wacom Intuos CTL4100 Battery Replacement, Battery: adım 1, 3 resimden 2. Wacom Intuos CTL4100 Battery Replacement, Battery: adım 1, 3 resimden 3.
    • Flip the tablet over so the bottom case faces upwards.
    • Remove the rubber pads on the corners by pulling them up with your fingers.
  2. Wacom Intuos CTL4100 Battery Replacement: adım 2, 3 resimden 1. Wacom Intuos CTL4100 Battery Replacement: adım 2, 3 resimden 2. Wacom Intuos CTL4100 Battery Replacement: adım 2, 3 resimden 3.
  3. Wacom Intuos CTL4100 Battery Replacement: adım 3, 3 resimden 1. Wacom Intuos CTL4100 Battery Replacement: adım 3, 3 resimden 2. Wacom Intuos CTL4100 Battery Replacement: adım 3, 3 resimden 3.
    • Insert a plastic opening pick between the front and back case to unclip the clips that hold the cases together.
    • Slide your plastic opening pick around the sides until all clips are unclipped.
  4. Wacom Intuos CTL4100 Battery Replacement: adım 4, 2 resimden 1. Wacom Intuos CTL4100 Battery Replacement: adım 4, 2 resimden 2.
    • Lift the bottom case to separate the top and bottom case
    • When you see the internal components, set aside the bottom case.
  5. Wacom Intuos CTL4100 Battery Replacement: adım 5, 2 resimden 1. Wacom Intuos CTL4100 Battery Replacement: adım 5, 2 resimden 2.
    • Remove the yellow tape that is on top of the battery wires.
    • When the battery wires under the tape are exposed, stick the yellow tape just above the battery wires.
  6. Wacom Intuos CTL4100 Battery Replacement: adım 6, 2 resimden 1. Wacom Intuos CTL4100 Battery Replacement: adım 6, 2 resimden 2.
    • Gently pull up the battery wire pin with your fingers to disconnect the pin from the motherboard.
  7. Wacom Intuos CTL4100 Battery Replacement: adım 7, 2 resimden 1. Wacom Intuos CTL4100 Battery Replacement: adım 7, 2 resimden 2.
    • Remove the battery by lifting the battery up with your fingers.
  8. Wacom Intuos CTL4100 Battery Replacement: adım 8, 1 resimden 1.
    • Place the new battery on the area you removed the battery.
  9. Wacom Intuos CTL4100 Battery Replacement: adım 9, 2 resimden 1. Wacom Intuos CTL4100 Battery Replacement: adım 9, 2 resimden 2.
    • Gently connect the battery wire pin to the motherboard.
  10. Wacom Intuos CTL4100 Battery Replacement: adım 10, 2 resimden 1. Wacom Intuos CTL4100 Battery Replacement: adım 10, 2 resimden 2.
    • Reapply the tape you put above the battery wires.
Sonuç
To reassemble your device, follow step 4 in reverse order.
3 farklı kişi bu kılavuzu tamamladı.
Marcus Sisouphanh
262 İtibar
1 Kılavuz yazıldı
Ekip
York University, Team 1-24, O'Regan Fall 2021 York University, Team 1-24, O'Regan Fall 2021 üyesi
YORK-O'REGAN-F21S1G24
1 Üye
2 adet Kılavuz yazıldı
3 Yorum
Where did you get the replacement battery?
David VeLar - Yanıt
Will it work without a battery?
Jordi Prats - Yanıt
Answering my own question, yes, it works without a battery. It will popup a notification of low battery sometimes, and obviously it won't work wirelessly.
Ah, and I tried this with a CTL6100 tablet, so this guide is valid for this model as well (a bit larger but mostly identical inside).
Jordi Prats -
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 7
Son 7 gün: 24
Son 30 gün: 110
Her zaman: 3,449
