Ana içeriğe geç
Wacom Intuos Pro Battery Replacement
Neye ihtiyacın var
    1. Wacom Intuos Pro Battery Replacement, Battery: adım 1, 3 resimden 1. Wacom Intuos Pro Battery Replacement, Battery: adım 1, 3 resimden 2. Wacom Intuos Pro Battery Replacement, Battery: adım 1, 3 resimden 3.
      • Orient the device so the bottom casing is facing upwards.
      • Use your fingers to gently pull on the rubber covers on the bottom of the device to remove them.
      FixBot'a Sor
      Yorum Ekle
    2. Wacom Intuos Pro Battery Replacement: adım 2, 3 resimden 1. Wacom Intuos Pro Battery Replacement: adım 2, 3 resimden 2. Wacom Intuos Pro Battery Replacement: adım 2, 3 resimden 3.
      • Remove the four 4mm screws from underneath the rubber feet using a Phillips #00 screwdriver.
      • The screws are located 40mm in from the edge, so it not necessary to completely remove the rubber if you prefer not to.
      FixBot'a Sor
      Yorum Ekle
    3. Wacom Intuos Pro Battery Replacement: adım 3, 2 resimden 1. Wacom Intuos Pro Battery Replacement: adım 3, 2 resimden 2.
      • Insert the iFixit Opening Tool between the front and back cover of the device in order to snap and separate the type locks from around the edges.
      • Use the iFixit Opening Tool all the way around the edges until all the snaps have been released.
      • While going around the edges, make sure you have a tight grip to keep the device from sliding.
      FixBot'a Sor
      Yorum Ekle
    4. Wacom Intuos Pro Battery Replacement: adım 4, 2 resimden 1. Wacom Intuos Pro Battery Replacement: adım 4, 2 resimden 2.
      • Remove the case backing from the rear of the device with your hands so the internal components are exposed.
      FixBot'a Sor
      Yorum Ekle
    5. Wacom Intuos Pro Battery Replacement: adım 5, 2 resimden 1. Wacom Intuos Pro Battery Replacement: adım 5, 2 resimden 2.
      • If not already done, desolder the three colored cables that connect the battery to the motherboard.
      • After desoldering the battery, carefully remove it.
      • Be careful when handling the soldering iron given it's high operating temperature and the possibility for it to damage other components.
      • For help soldering, check out our How to Solder and Desolder Connections guide.
      FixBot'a Sor
      Yorum Ekle
Sonuç
3 farklı kişi bu kılavuzu tamamladı.
7Kılavuz Yorumları
thank you so much. I plan to buy this wacom, however I had the doubt if better the old version that has extractable battery, but with this post, I can go for the new one
Sebastian Ramirez - Yanıt Paylaş
Do you know where can I find the battery replacement?
Valerio _ - Yanıt Paylaş
Has anyone got a lint to the replacement battery?
Luca Di Meo - Yanıt Paylaş
PTH-660 works fine without the battery, just remove it and use it with USB cable
Where can I find a replacement battery for this model?
Denise Hanly - Yanıt Paylaş
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 9
Son 7 gün: 51
Son 30 gün: 190
Her zaman: 11,764
