Ana içeriğe geç
Wacom Intuos Pro Touch Pad Replacement
Neye ihtiyacın var
  1. Wacom Intuos Pro Touch Pad Replacement, Battery: adım 1, 3 resimden 1. Wacom Intuos Pro Touch Pad Replacement, Battery: adım 1, 3 resimden 2. Wacom Intuos Pro Touch Pad Replacement, Battery: adım 1, 3 resimden 3.
    • Orient the device so the bottom casing is facing upwards.
    • Use your fingers to gently pull on the rubber covers on the bottom of the device to remove them.
  2. Wacom Intuos Pro Touch Pad Replacement: adım 2, 3 resimden 1. Wacom Intuos Pro Touch Pad Replacement: adım 2, 3 resimden 2. Wacom Intuos Pro Touch Pad Replacement: adım 2, 3 resimden 3.
    • Remove the four 4mm screws from underneath the rubber feet using a Phillips #00 screwdriver.
  3. Wacom Intuos Pro Touch Pad Replacement: adım 3, 2 resimden 1. Wacom Intuos Pro Touch Pad Replacement: adım 3, 2 resimden 2.
    • Insert the iFixit Opening Tool between the front and back cover of the device in order to snap and separate the type locks from around the edges.
    • Use the iFixit Opening Tool all the way around the edges until all the snaps have been released.
    • While going around the edges, make sure you have a tight grip to keep the device from sliding.
  4. Wacom Intuos Pro Touch Pad Replacement: adım 4, 2 resimden 1. Wacom Intuos Pro Touch Pad Replacement: adım 4, 2 resimden 2.
    • Remove the case backing from the rear of the device with your hands so the internal components are exposed.
  5. Wacom Intuos Pro Touch Pad Replacement: adım 5, 2 resimden 1. Wacom Intuos Pro Touch Pad Replacement: adım 5, 2 resimden 2.
    • If not already done, desolder the three colored cables that connect the battery to the motherboard.
    • After desoldering the battery, carefully remove it.
    • Be careful when handling the soldering iron given it's high operating temperature and the possibility for it to damage other components.
    • For help soldering, check out our How to Solder and Desolder Connections guide.
  6. Wacom Intuos Pro Touch Pad Replacement, Touch Pad: adım 6, 1 resimden 1.
    • Gently pull the blue tabs on the four ribbon cables from the ZIF connectors on the motherboard.
  7. Wacom Intuos Pro Touch Pad Replacement: adım 7, 1 resimden 1.
    • Remove the five 4.5mm screws using a Phillips #00 screwdriver.
  8. Wacom Intuos Pro Touch Pad Replacement: adım 8, 2 resimden 1. Wacom Intuos Pro Touch Pad Replacement: adım 8, 2 resimden 2.
    • Gently wedge the Jimmy under the black backing of the blue touchpad.
    • Gently pry up the touchpad and remove it from the case.
Sonuç
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 1
Son 7 gün: 7
Son 30 gün: 34
Her zaman: 1,267
