Ana içeriğe geç
Wahl Precision Adjustable Clippers Blade Replacement & Alignment
Samuel Worku
Samuel Worku ve 2 diğer katkıda bulunanlar
En son July 15, 2024 tarihinde güncellendi
10 - 15 dakika
Orta
The guide will teach you to take apart, sharpen, and reassemble a Wahl (model #NAC) hair clipper. Men who use grooming clippers to cut their own or other people's hair can use this solution. Any grooming gadget from Wahl, Oster, Remington, Babyliss, and others can be fixed with this fix. This is required when everything is pricey, from getting a haircut to replacing your clippers. Therefore, I came up with a solution for those who cut their hair or wish to work in the barbershop industry but lack the funds to purchase new clippers. They may use this tutorial to repair their current clippers and use them.
  1. Wahl Precision Adjustable Clippers Blade Replacement & Alignment, Blade: adım 1, 3 resimden 1. Wahl Precision Adjustable Clippers Blade Replacement & Alignment, Blade: adım 1, 3 resimden 2. Wahl Precision Adjustable Clippers Blade Replacement & Alignment, Blade: adım 1, 3 resimden 3.
    • Clean dirt and hair from the clipper using a small brush.
  2. Wahl Precision Adjustable Clippers Blade Replacement & Alignment: adım 2, 3 resimden 1. Wahl Precision Adjustable Clippers Blade Replacement & Alignment: adım 2, 3 resimden 2. Wahl Precision Adjustable Clippers Blade Replacement & Alignment: adım 2, 3 resimden 3.
    • Rest the top blade on the clipper and put the bottom blade on top with the flat side facing toward the top blade. Tighten the screws to hold the blades in place.
  3. Wahl Precision Adjustable Clippers Blade Replacement & Alignment: adım 3, 3 resimden 1. Wahl Precision Adjustable Clippers Blade Replacement & Alignment: adım 3, 3 resimden 2. Wahl Precision Adjustable Clippers Blade Replacement & Alignment: adım 3, 3 resimden 3.
    • Oil the underside of the bottom blade.
Sonuç
Enjoy your new blade!
Samuel Worku
310 İtibar
2 adet Kılavuz yazıldı
Ekip
CSU Los Angeles, Team 13-6, Briggs Fall 2022 CSU Los Angeles, Team 13-6, Briggs Fall 2022 üyesi
CSULA-BRIGGS-F22S13G6
1 Üye
4 adet Kılavuz yazıldı
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 7
Son 7 gün: 40
Son 30 gün: 123
Her zaman: 4,361
