Ana içeriğe geç
Weinmann VENTImotion and VENTIlogic Fascia Film Replacement
Tıbbi Ekipman
iFixit de, bu onarım kılavuzu da tıbbi cihaz üreticisi tarafından onaylanmış değildir ya da herhangi birinin üreticiyle alâkası yoktur.
Neye ihtiyacın var
  1. Weinmann VENTImotion and VENTIlogic Fascia Film Replacement, Fascia Film: adım 1, 1 resimden 1.
    • Open the device
    • 1.Place the device on a non-slip surface with the top facing downwards
    • 2.Remove the filter cassette from the top part of the housing.
    • 3.Undo and remove the 6 screws (34)
  2. Weinmann VENTImotion and VENTIlogic Fascia Film Replacement: adım 2, 1 resimden 1.
    • Remove the mains supply unit
    • Disconnect the power board/mains supply unit connecting cable (45) from the power board.
    • Slightly lift mains supply unit (44) and disconnect the mains input connector from the mains supply unit (44).
    • Lift the mains supply unit out of the top part of the housing.
    • Disconnect the power board/mains supply unit connecting cable from the mains supply unit.
  3. Weinmann VENTImotion and VENTIlogic Fascia Film Replacement: adım 4, 2 resimden 1. Weinmann VENTImotion and VENTIlogic Fascia Film Replacement: adım 4, 2 resimden 2.
    • Remove box and filter holder
    • Release the pressure-side hose (74) from the box.
    • Lift box (58) and filter holder (37) out of the top part of the housing together.
    • Disconnect the box and the filter holder from one another by undoing the intake-side hose (73) from both parts.
  4. Weinmann VENTImotion and VENTIlogic Fascia Film Replacement: adım 5, 1 resimden 1.
  5. Weinmann VENTImotion and VENTIlogic Fascia Film Replacement: adım 6, 1 resimden 1.
    • Peel the protective film off the inside of the new fascia film and affix fascia film (33) to this area of the housing.
    • Ensure that the ribbon cable is pushed cleanly through the opening in the housing without any kinks.
    • Carefully pull the outer protective film off the new fascia film using a fingernail.
  6. Weinmann VENTImotion and VENTIlogic Fascia Film Replacement: adım 9, 2 resimden 1. Weinmann VENTImotion and VENTIlogic Fascia Film Replacement: adım 9, 2 resimden 2.
    • Refit the box and filter holder.
    • Connect the box and the filter holder to one another by reconnecting the intake side hose (73) from both parts.
    • Refit box (58) and filter holder (37) back on the top part of the housing together.
    • Connect the pressure-side hose (74) from the box.
  7. Weinmann VENTImotion and VENTIlogic Fascia Film Replacement: adım 11, 1 resimden 1.
    • Refit the mains supply unit
    • Reconnect the power board/mains supply unit connecting cable from the mains supply unit.
    • Put the mains supply unit back in the top part of the housing.
    • Reconnect the mains input connector from the mains supply unit (44).
    • Reconnect the power board/mains supply unit connecting cable (45) from the power board.
  8. Weinmann VENTImotion and VENTIlogic Fascia Film Replacement: adım 12, 2 resimden 1. Weinmann VENTImotion and VENTIlogic Fascia Film Replacement: adım 12, 2 resimden 2.
    • Close the device
    • Hold the bottom part of the housing (35) up to the side of the top part of the housing (36)
    • Plug the connecting cables for the humidifier (42) and the alarm (43) onto the relevant connectors.
    • Check that all hoses and cables are plugged on firmly.
    • Place the bottom part of the housing (35) on the top part of the housing (36). Ensure that no cables or hoses are trapped or bent.
    • Now screw the top part of the housing tight using the 6 screws (34).
    • Then turn the device back over
Sonuç
2 farklı kişi bu kılavuzu tamamladı.
Jay Vidinoff
610 İtibar
2 adet Kılavuz yazıldı
Ekip
Cal Poly, Team S7-G19, Paton Spring 2020 Cal Poly, Team S7-G19, Paton Spring 2020 üyesi
CPSU-PATON-S20S7G19
3 Üyeler
4 adet Kılavuz yazıldı
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 1
Son 30 gün: 3
Her zaman: 123
