Ana içeriğe geç
Weller WLC100 Soldering Station NTW56058 TRIAC 16amp switch Replacement
Neye ihtiyacın var
  1. Weller WLC100 Soldering Station  NTW56058 TRIAC 16amp switch Replacement, NTW56058 TRIAC 16amp switch: adım 1, 1 resimden 1.
    • Remove the knob from the adjustment dial.
  2. Weller WLC100 Soldering Station  NTW56058 TRIAC 16amp switch Replacement: adım 2, 1 resimden 1.
    • Remove two 8.6 mm Phillips #1 screws from soldering station bottom.
  3. Weller WLC100 Soldering Station  NTW56058 TRIAC 16amp switch Replacement: adım 3, 1 resimden 1.
    • Remove the rubber feet to access the remaining screws.
  4. Weller WLC100 Soldering Station  NTW56058 TRIAC 16amp switch Replacement: adım 4, 1 resimden 1.
    • Remove the remaining two 8.6 mm Phillips #1 screws from soldering station bottom.
  5. Weller WLC100 Soldering Station  NTW56058 TRIAC 16amp switch Replacement: adım 5, 1 resimden 1.
    • Separate the bottom and top half of the soldering station.
  6. Weller WLC100 Soldering Station  NTW56058 TRIAC 16amp switch Replacement: adım 6, 1 resimden 1.
    • Remove the adjustable heat dial board.
  7. Weller WLC100 Soldering Station  NTW56058 TRIAC 16amp switch Replacement: adım 7, 2 resimden 1. Weller WLC100 Soldering Station  NTW56058 TRIAC 16amp switch Replacement: adım 7, 2 resimden 2.
    • Orient the new TRIAC switch the same way as the old TRIAC switch is located.
  8. Weller WLC100 Soldering Station  NTW56058 TRIAC 16amp switch Replacement: adım 8, 2 resimden 1. Weller WLC100 Soldering Station  NTW56058 TRIAC 16amp switch Replacement: adım 8, 2 resimden 2.
  9. Weller WLC100 Soldering Station  NTW56058 TRIAC 16amp switch Replacement: adım 9, 1 resimden 1.
    • Remove the TRIAC switch when all the solder is removed from the pins.
  10. Weller WLC100 Soldering Station  NTW56058 TRIAC 16amp switch Replacement: adım 10, 1 resimden 1.
    • Insert the new TRIAC switch into the three holes left when you removed the old TRIAC switch.
  11. Weller WLC100 Soldering Station  NTW56058 TRIAC 16amp switch Replacement: adım 11, 1 resimden 1.
    • Solder the new TRIAC switch onto board.
  12. Weller WLC100 Soldering Station  NTW56058 TRIAC 16amp switch Replacement: adım 12, 1 resimden 1.
    • Verify all three pins are soldered in and the solder is not touching the other pins.
  13. Weller WLC100 Soldering Station  NTW56058 TRIAC 16amp switch Replacement: adım 13, 1 resimden 1.
    • Re-install the board into the soldering station.
  14. Weller WLC100 Soldering Station  NTW56058 TRIAC 16amp switch Replacement: adım 14, 1 resimden 1.
    • Push the knob into the hole so that is it protruding out of the other side.
  15. Weller WLC100 Soldering Station  NTW56058 TRIAC 16amp switch Replacement: adım 15, 1 resimden 1.
    • Verify the knob is sticking out of the other side of soldering station.
  16. Weller WLC100 Soldering Station  NTW56058 TRIAC 16amp switch Replacement: adım 16, 1 resimden 1.
    • Replace the dial onto the knob.
  17. Weller WLC100 Soldering Station  NTW56058 TRIAC 16amp switch Replacement: adım 17, 1 resimden 1.
    • Replace the bottom and replace all four screws and rubber feet, reversing steps four though two.
Sonuç
2 farklı kişi bu kılavuzu tamamladı.
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 1
Son 7 gün: 7
Son 30 gün: 34
Her zaman: 1,346
