Ana içeriğe geç
Weller WLC100 Soldering Station NTW56058 TRIAC 16amp switch Replacement
Neye ihtiyacın var
    1. Weller WLC100 Soldering Station  NTW56058 TRIAC 16amp switch Replacement, NTW56058 TRIAC 16amp switch: adım 1, 1 resimden 1.
      • Remove the knob from the adjustment dial.
      FixBot'a Sor
      Yorum Ekle
    2. Weller WLC100 Soldering Station  NTW56058 TRIAC 16amp switch Replacement: adım 2, 1 resimden 1.
      • Remove two 8.6 mm Phillips #1 screws from soldering station bottom.
      FixBot'a Sor
      Yorum Ekle
    3. Weller WLC100 Soldering Station  NTW56058 TRIAC 16amp switch Replacement: adım 3, 1 resimden 1.
      • Remove the rubber feet to access the remaining screws.
      FixBot'a Sor
      Yorum Ekle
    4. Weller WLC100 Soldering Station  NTW56058 TRIAC 16amp switch Replacement: adım 4, 1 resimden 1.
      • Remove the remaining two 8.6 mm Phillips #1 screws from soldering station bottom.
      FixBot'a Sor
      Yorum Ekle
    5. Weller WLC100 Soldering Station  NTW56058 TRIAC 16amp switch Replacement: adım 5, 1 resimden 1.
      • Separate the bottom and top half of the soldering station.
      FixBot'a Sor
      Yorum Ekle
    6. Weller WLC100 Soldering Station  NTW56058 TRIAC 16amp switch Replacement: adım 6, 1 resimden 1.
      • Remove the adjustable heat dial board.
      FixBot'a Sor
      Yorum Ekle
    7. Weller WLC100 Soldering Station  NTW56058 TRIAC 16amp switch Replacement: adım 7, 2 resimden 1. Weller WLC100 Soldering Station  NTW56058 TRIAC 16amp switch Replacement: adım 7, 2 resimden 2.
      • Orient the new TRIAC switch the same way as the old TRIAC switch is located.
      FixBot'a Sor
      Yorum Ekle
    8. Weller WLC100 Soldering Station  NTW56058 TRIAC 16amp switch Replacement: adım 8, 2 resimden 1. Weller WLC100 Soldering Station  NTW56058 TRIAC 16amp switch Replacement: adım 8, 2 resimden 2.
      FixBot'a Sor
      Yorum Ekle
    9. Weller WLC100 Soldering Station  NTW56058 TRIAC 16amp switch Replacement: adım 9, 1 resimden 1.
      • Remove the TRIAC switch when all the solder is removed from the pins.
      FixBot'a Sor
      Yorum Ekle
    10. Weller WLC100 Soldering Station  NTW56058 TRIAC 16amp switch Replacement: adım 10, 1 resimden 1.
      • Insert the new TRIAC switch into the three holes left when you removed the old TRIAC switch.
      FixBot'a Sor
      Yorum Ekle
    11. Weller WLC100 Soldering Station  NTW56058 TRIAC 16amp switch Replacement: adım 11, 1 resimden 1.
      • Solder the new TRIAC switch onto board.
      FixBot'a Sor
      Yorum Ekle
    12. Weller WLC100 Soldering Station  NTW56058 TRIAC 16amp switch Replacement: adım 12, 1 resimden 1.
      • Verify all three pins are soldered in and the solder is not touching the other pins.
      FixBot'a Sor
      Yorum Ekle
    13. Weller WLC100 Soldering Station  NTW56058 TRIAC 16amp switch Replacement: adım 13, 1 resimden 1.
      • Re-install the board into the soldering station.
      FixBot'a Sor
      Yorum Ekle
    14. Weller WLC100 Soldering Station  NTW56058 TRIAC 16amp switch Replacement: adım 14, 1 resimden 1.
      • Push the knob into the hole so that is it protruding out of the other side.
      FixBot'a Sor
      Yorum Ekle
    15. Weller WLC100 Soldering Station  NTW56058 TRIAC 16amp switch Replacement: adım 15, 1 resimden 1.
      • Verify the knob is sticking out of the other side of soldering station.
      FixBot'a Sor
      Yorum Ekle
    16. Weller WLC100 Soldering Station  NTW56058 TRIAC 16amp switch Replacement: adım 16, 1 resimden 1.
      • Replace the dial onto the knob.
      FixBot'a Sor
      Yorum Ekle
    17. Weller WLC100 Soldering Station  NTW56058 TRIAC 16amp switch Replacement: adım 17, 1 resimden 1.
      • Replace the bottom and replace all four screws and rubber feet, reversing steps four though two.
      FixBot'a Sor
      Yorum Ekle
Sonuç
2 farklı kişi bu kılavuzu tamamladı.
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 3
Son 7 gün: 20
Son 30 gün: 64
Her zaman: 2,341
