Ana içeriğe geç
Whirlpool Dryer Control Panel Replacement
Neye ihtiyacın var
  1. Whirlpool Dryer Control Panel Replacement, Safety Precautions: adım 1, 1 resimden 1.
    • Before you begin your repair, unplug your dryer.
    • Your power cord may have four prongs rather than three. The additional prong is a ground connection.
  2. Whirlpool Dryer Control Panel Replacement, Unfasten the top panel: adım 2, 3 resimden 1. Whirlpool Dryer Control Panel Replacement, Unfasten the top panel: adım 2, 3 resimden 2. Whirlpool Dryer Control Panel Replacement, Unfasten the top panel: adım 2, 3 resimden 3.
    Bu adımda kullanılan alet:
    FixMat
    $36.95
    • Throughout this guide, keep track of each screw and reinstall it exactly where it came from.
    • Use a nut driver to remove the screws securing the top panel to the rear panel bracket.
  3. Whirlpool Dryer Control Panel Replacement, Remove the top panel: adım 3, 2 resimden 1. Whirlpool Dryer Control Panel Replacement, Remove the top panel: adım 3, 2 resimden 2.
    • Grasp the top and slide it 1/2 to 1 inch toward the rear of the machine.
  4. Whirlpool Dryer Control Panel Replacement: adım 4, 2 resimden 1. Whirlpool Dryer Control Panel Replacement: adım 4, 2 resimden 2.
    • Lift the top panel upward to separate it from the chassis.
    • Remove the top panel from the machine.
  5. Whirlpool Dryer Control Panel Replacement, Disconnect the control panel: adım 5, 2 resimden 1. Whirlpool Dryer Control Panel Replacement, Disconnect the control panel: adım 5, 2 resimden 2.
    • Disconnect the control panel cable from the main board.
  6. Whirlpool Dryer Control Panel Replacement: adım 6, 2 resimden 1. Whirlpool Dryer Control Panel Replacement: adım 6, 2 resimden 2.
    • Disconnect the drum light connector.
  7. Whirlpool Dryer Control Panel Replacement, Unfasten the control panel: adım 7, 2 resimden 1. Whirlpool Dryer Control Panel Replacement, Unfasten the control panel: adım 7, 2 resimden 2.
    • Remove the screws securing the control panel.
  8. Whirlpool Dryer Control Panel Replacement, Remove the control panel: adım 8, 3 resimden 1. Whirlpool Dryer Control Panel Replacement, Remove the control panel: adım 8, 3 resimden 2. Whirlpool Dryer Control Panel Replacement, Remove the control panel: adım 8, 3 resimden 3.
    • Lift the control panel up and tilt it away from the chassis to remove it.
    • Make sure to thread the cable through the hole in the chassis.
    • During reassembly, thread the cable through its proper hole before reinstalling the control panel.
  9. Whirlpool Dryer Control Panel Replacement, Remove the wiring harness: adım 9, 3 resimden 1. Whirlpool Dryer Control Panel Replacement, Remove the wiring harness: adım 9, 3 resimden 2. Whirlpool Dryer Control Panel Replacement, Remove the wiring harness: adım 9, 3 resimden 3.
    • Disconnect the wiring harness connectors.
    • Lay the control panel down on a towel or other soft surface to perform the next few steps.
  10. Whirlpool Dryer Control Panel Replacement, Unfasten the control board: adım 10, 1 resimden 1.
    • Remove the screws which secure the front control board to its housing.
  11. Whirlpool Dryer Control Panel Replacement, Remove the control panel unit: adım 11, 3 resimden 1. Whirlpool Dryer Control Panel Replacement, Remove the control panel unit: adım 11, 3 resimden 2. Whirlpool Dryer Control Panel Replacement, Remove the control panel unit: adım 11, 3 resimden 3.
    • Lift up the back plate off the control panel and remove it.
    • The control panel is a circuit board attached to a face plate. Replace the entire unit if possible.
Sonuç
Repair didn’t go as planned? Ask our Answers community for help.
Bill Gilbert
37.485 İtibar
261 adet Kılavuz yazıldı
Ekip
iFixit iFixit üyesi
Staff
121 Üyeler
19.674 adet Kılavuz yazıldı
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 8
Son 7 gün: 22
Son 30 gün: 101
Her zaman: 1,727
