Ana içeriğe geç
Whirlpool Refrigerator Condenser Fan Replacement
Neye ihtiyacın var
    1. Whirlpool Refrigerator Condenser Fan Replacement, Safety precautions: adım 1, 1 resimden 1.
      • Before you begin your repair, perform the following:
      • Turn off your main water supply
      • Unplug your device
      FixBot'a Sor
      Yorum Ekle
    1. Whirlpool Refrigerator Condenser Fan Replacement, Unfasten the rear panel: adım 2, 3 resimden 1. Whirlpool Refrigerator Condenser Fan Replacement, Unfasten the rear panel: adım 2, 3 resimden 2. Whirlpool Refrigerator Condenser Fan Replacement, Unfasten the rear panel: adım 2, 3 resimden 3.
      • Remove the screw(s) securing the rear panel.
      • Loosen the screw securing the water hose enough for the rear panel to freely move.
      FixBot'a Sor
      Yorum Ekle
    2. Whirlpool Refrigerator Condenser Fan Replacement, Remove the rear panel: adım 3, 3 resimden 1. Whirlpool Refrigerator Condenser Fan Replacement, Remove the rear panel: adım 3, 3 resimden 2. Whirlpool Refrigerator Condenser Fan Replacement, Remove the rear panel: adım 3, 3 resimden 3.
      • Pull the rear panel off the chassis to remove it.
      FixBot'a Sor
      Yorum Ekle
    1. Whirlpool Refrigerator Condenser Fan Replacement, Disconnect the condenser fan: adım 4, 2 resimden 1. Whirlpool Refrigerator Condenser Fan Replacement, Disconnect the condenser fan: adım 4, 2 resimden 2.
      • Disconnect the connector attached to the condenser fan.
      FixBot'a Sor
      Yorum Ekle
    2. Whirlpool Refrigerator Condenser Fan Replacement, Remove the condenser fan: adım 5, 3 resimden 1. Whirlpool Refrigerator Condenser Fan Replacement, Remove the condenser fan: adım 5, 3 resimden 2. Whirlpool Refrigerator Condenser Fan Replacement, Remove the condenser fan: adım 5, 3 resimden 3.
      • Put on gloves before continuing, as the sheet metal and the fan itself are sharp.
      • Pull the condenser fan straight off its peg to remove it.
      FixBot'a Sor
      Yorum Ekle
    3. Whirlpool Refrigerator Condenser Fan Replacement, Unfasten the condenser fan motor: adım 6, 1 resimden 1.
      • Remove the screw(s) securing the condenser fan motor to the chassis.
      FixBot'a Sor
      Yorum Ekle
    4. Whirlpool Refrigerator Condenser Fan Replacement, Remove the motor: adım 7, 3 resimden 1. Whirlpool Refrigerator Condenser Fan Replacement, Remove the motor: adım 7, 3 resimden 2. Whirlpool Refrigerator Condenser Fan Replacement, Remove the motor: adım 7, 3 resimden 3.
      • Rotate the motor housing through its slot in the chassis.
      • Remove the motor.
      FixBot'a Sor
      Yorum Ekle
Sonuç
Repair didn’t go as planned? Ask our Answers community for help.
5 farklı kişi bu kılavuzu tamamladı.
nicO
15.990 İtibar
89 adet Kılavuz yazıldı
1Rehber Yorum
Saludos una consulta el giro del motor es antihorario???
Edward Vasquez - Yanıt Paylaş
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 8
Son 7 gün: 41
Son 30 gün: 186
Her zaman: 5,449
