Ana içeriğe geç
Whirlpool Refrigerator Condenser Fan Replacement
Neye ihtiyacın var
  1. Whirlpool Refrigerator Condenser Fan Replacement, Safety precautions: adım 1, 1 resimden 1.
    • Before you begin your repair, perform the following:
    • Turn off your main water supply
    • Unplug your device
  2. Whirlpool Refrigerator Condenser Fan Replacement, Unfasten the rear panel: adım 2, 3 resimden 1. Whirlpool Refrigerator Condenser Fan Replacement, Unfasten the rear panel: adım 2, 3 resimden 2. Whirlpool Refrigerator Condenser Fan Replacement, Unfasten the rear panel: adım 2, 3 resimden 3.
    • Remove the screw(s) securing the rear panel.
    • Loosen the screw securing the water hose enough for the rear panel to freely move.
  3. Whirlpool Refrigerator Condenser Fan Replacement, Remove the rear panel: adım 3, 3 resimden 1. Whirlpool Refrigerator Condenser Fan Replacement, Remove the rear panel: adım 3, 3 resimden 2. Whirlpool Refrigerator Condenser Fan Replacement, Remove the rear panel: adım 3, 3 resimden 3.
    • Pull the rear panel off the chassis to remove it.
  4. Whirlpool Refrigerator Condenser Fan Replacement, Disconnect the condenser fan: adım 4, 2 resimden 1. Whirlpool Refrigerator Condenser Fan Replacement, Disconnect the condenser fan: adım 4, 2 resimden 2.
    • Disconnect the connector attached to the condenser fan.
  5. Whirlpool Refrigerator Condenser Fan Replacement, Remove the condenser fan: adım 5, 3 resimden 1. Whirlpool Refrigerator Condenser Fan Replacement, Remove the condenser fan: adım 5, 3 resimden 2. Whirlpool Refrigerator Condenser Fan Replacement, Remove the condenser fan: adım 5, 3 resimden 3.
    • Put on gloves before continuing, as the sheet metal and the fan itself are sharp.
    • Pull the condenser fan straight off its peg to remove it.
  6. Whirlpool Refrigerator Condenser Fan Replacement, Unfasten the condenser fan motor: adım 6, 1 resimden 1.
    • Remove the screw(s) securing the condenser fan motor to the chassis.
  7. Whirlpool Refrigerator Condenser Fan Replacement, Remove the motor: adım 7, 3 resimden 1. Whirlpool Refrigerator Condenser Fan Replacement, Remove the motor: adım 7, 3 resimden 2. Whirlpool Refrigerator Condenser Fan Replacement, Remove the motor: adım 7, 3 resimden 3.
    • Rotate the motor housing through its slot in the chassis.
    • Remove the motor.
Sonuç
Repair didn’t go as planned? Ask our Answers community for help.
3 farklı kişi bu kılavuzu tamamladı.
nicO
15.927 İtibar
89 adet Kılavuz yazıldı
Ekip
Global Fixers Global Fixers üyesi
Community
45 Üyeler
700 adet Kılavuz yazıldı
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 5
Son 7 gün: 40
Son 30 gün: 98
Her zaman: 2,782
