Ana içeriğe geç
Whirlpool Refrigerator Defrost Heater Replacement
Neye ihtiyacın var
  1. Whirlpool Refrigerator Defrost Heater Replacement, Safety precautions: adım 1, 1 resimden 1.
    • Before you begin your repair, perform the following:
    • Turn off your main water supply
    • Unplug your device
  2. Whirlpool Refrigerator Defrost Heater Replacement, Open the doors: adım 2, 3 resimden 1. Whirlpool Refrigerator Defrost Heater Replacement, Open the doors: adım 2, 3 resimden 2. Whirlpool Refrigerator Defrost Heater Replacement, Open the doors: adım 2, 3 resimden 3.
    • Depending on your repair, open one or both doors.
  3. Whirlpool Refrigerator Defrost Heater Replacement, Remove the drawers: adım 3, 2 resimden 1. Whirlpool Refrigerator Defrost Heater Replacement, Remove the drawers: adım 3, 2 resimden 2.
    • Remove the drawers and shelves from the freezer section.
  4. Whirlpool Refrigerator Defrost Heater Replacement: adım 4, 2 resimden 1. Whirlpool Refrigerator Defrost Heater Replacement: adım 4, 2 resimden 2.
    • Remove the screw(s) securing the evaporator cover.
  5. Whirlpool Refrigerator Defrost Heater Replacement, Unclip the evaporator cover: adım 5, 3 resimden 1. Whirlpool Refrigerator Defrost Heater Replacement, Unclip the evaporator cover: adım 5, 3 resimden 2. Whirlpool Refrigerator Defrost Heater Replacement, Unclip the evaporator cover: adım 5, 3 resimden 3.
    • Lift the bottom of the evaporator cover up and over its lip in the chassis.
    • Pull the cover toward yourself to release its top clips.
  6. Whirlpool Refrigerator Defrost Heater Replacement, Remove the evaporator cover: adım 6, 3 resimden 1. Whirlpool Refrigerator Defrost Heater Replacement, Remove the evaporator cover: adım 6, 3 resimden 2. Whirlpool Refrigerator Defrost Heater Replacement, Remove the evaporator cover: adım 6, 3 resimden 3.
    • Continue pulling the evaporator cover towards yourself to unclip its metal prongs from the chassis.
    • Remove the evaporator cover.
  7. Whirlpool Refrigerator Defrost Heater Replacement, Disconnect the defrost heater: adım 7, 3 resimden 1. Whirlpool Refrigerator Defrost Heater Replacement, Disconnect the defrost heater: adım 7, 3 resimden 2. Whirlpool Refrigerator Defrost Heater Replacement, Disconnect the defrost heater: adım 7, 3 resimden 3.
    • Disconnect the connector(s) attached to the defrost heater.
  8. Whirlpool Refrigerator Defrost Heater Replacement, Reposition the cable: adım 8, 3 resimden 1. Whirlpool Refrigerator Defrost Heater Replacement, Reposition the cable: adım 8, 3 resimden 2. Whirlpool Refrigerator Defrost Heater Replacement, Reposition the cable: adım 8, 3 resimden 3.
    • Pull the defrost heater cable out from behind the evaporator.
  9. Whirlpool Refrigerator Defrost Heater Replacement, Unfasten the defrost heater bracket: adım 9, 1 resimden 1.
    • Remove the screw(s) securing the defrost heater bracket.
  10. Whirlpool Refrigerator Defrost Heater Replacement, Release the defrost heater bracket: adım 10, 2 resimden 1. Whirlpool Refrigerator Defrost Heater Replacement, Release the defrost heater bracket: adım 10, 2 resimden 2.
    • Pull the defrost heater bracket up to release it from its slot in the chassis.
  11. Whirlpool Refrigerator Defrost Heater Replacement, Remove the defrost heater: adım 11, 3 resimden 1. Whirlpool Refrigerator Defrost Heater Replacement, Remove the defrost heater: adım 11, 3 resimden 2. Whirlpool Refrigerator Defrost Heater Replacement, Remove the defrost heater: adım 11, 3 resimden 3.
    • Slide the defrost heater from under the evaporator.
    • You may need to pull one end at a time until it's completely removed.
  12. Whirlpool Refrigerator Defrost Heater Replacement, Only the defrost heater remains: adım 12, 1 resimden 1.
    • You're now left with the defrost heater.
Sonuç
Repair didn’t go as planned? Ask our Answers community for help.
5 farklı kişi bu kılavuzu tamamladı.
nicO
15.945 İtibar
89 adet Kılavuz yazıldı
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 9
Son 7 gün: 30
Son 30 gün: 130
Her zaman: 5,584
