Ana içeriğe geç
Whirlpool Refrigerator Dispenser Solenoid Replacement
Neye ihtiyacın var
  1. Whirlpool Refrigerator Dispenser Solenoid Replacement, Safety precautions: adım 1, 1 resimden 1.
    • Before you begin your repair, perform the following:
    • Turn off your main water supply
    • Unplug your device
  2. Whirlpool Refrigerator Dispenser Solenoid Replacement, Open the doors: adım 2, 3 resimden 1. Whirlpool Refrigerator Dispenser Solenoid Replacement, Open the doors: adım 2, 3 resimden 2. Whirlpool Refrigerator Dispenser Solenoid Replacement, Open the doors: adım 2, 3 resimden 3.
    • Depending on your repair, open one or both doors.
  3. Whirlpool Refrigerator Dispenser Solenoid Replacement, Remove the icemaker tray: adım 3, 2 resimden 1. Whirlpool Refrigerator Dispenser Solenoid Replacement, Remove the icemaker tray: adım 3, 2 resimden 2.
    • Pull the icemaker tray completely out of its slot in the chassis.
  4. Whirlpool Refrigerator Dispenser Solenoid Replacement, Unfasten the icemaker assembly: adım 4, 2 resimden 1. Whirlpool Refrigerator Dispenser Solenoid Replacement, Unfasten the icemaker assembly: adım 4, 2 resimden 2.
    • Remove the screw(s) securing the icemaker assembly.
    • The second photo shows the potential screw locations in a removed icemaker assembly.
  5. Whirlpool Refrigerator Dispenser Solenoid Replacement, Reposition the icemaker assembly: adım 5, 3 resimden 1. Whirlpool Refrigerator Dispenser Solenoid Replacement, Reposition the icemaker assembly: adım 5, 3 resimden 2. Whirlpool Refrigerator Dispenser Solenoid Replacement, Reposition the icemaker assembly: adım 5, 3 resimden 3.
    • Pull the icemaker assembly off its slot in the chassis.
    • Let the assembly hang to access its connectors.
  6. Whirlpool Refrigerator Dispenser Solenoid Replacement, Disconnect the icemaker assembly: adım 6, 3 resimden 1. Whirlpool Refrigerator Dispenser Solenoid Replacement, Disconnect the icemaker assembly: adım 6, 3 resimden 2. Whirlpool Refrigerator Dispenser Solenoid Replacement, Disconnect the icemaker assembly: adım 6, 3 resimden 3.
    • Disconnect any connectors attached to the icemaker assembly.
  7. Whirlpool Refrigerator Dispenser Solenoid Replacement, Remove the icemaker assembly: adım 7, 1 resimden 1.
    • Remove the icemaker assembly.
  8. Whirlpool Refrigerator Dispenser Solenoid Replacement, Unfasten the icemaker auger assembly: adım 8, 1 resimden 1.
    • Remove the screw(s) securing the icemaker auger assembly.
  9. Whirlpool Refrigerator Dispenser Solenoid Replacement, Reposition the icemaker auger assembly: adım 9, 3 resimden 1. Whirlpool Refrigerator Dispenser Solenoid Replacement, Reposition the icemaker auger assembly: adım 9, 3 resimden 2. Whirlpool Refrigerator Dispenser Solenoid Replacement, Reposition the icemaker auger assembly: adım 9, 3 resimden 3.
    • Pull the icemaker auger assembly off of its slot in the chassis.
  10. Whirlpool Refrigerator Dispenser Solenoid Replacement, Disconnect the icemaker auger assembly: adım 10, 3 resimden 1. Whirlpool Refrigerator Dispenser Solenoid Replacement, Disconnect the icemaker auger assembly: adım 10, 3 resimden 2. Whirlpool Refrigerator Dispenser Solenoid Replacement, Disconnect the icemaker auger assembly: adım 10, 3 resimden 3.
    • Disconnect any connectors attached to the icemaker auger assembly.
  11. Whirlpool Refrigerator Dispenser Solenoid Replacement, Remove the icemaker auger assembly: adım 11, 1 resimden 1.
    • Remove the icemaker auger assembly.
  12. Whirlpool Refrigerator Dispenser Solenoid Replacement, Remove the dispenser: adım 12, 3 resimden 1. Whirlpool Refrigerator Dispenser Solenoid Replacement, Remove the dispenser: adım 12, 3 resimden 2. Whirlpool Refrigerator Dispenser Solenoid Replacement, Remove the dispenser: adım 12, 3 resimden 3.
    • Slide the dispenser head out of its slot in the icemaker auger assembly.
  13. Whirlpool Refrigerator Dispenser Solenoid Replacement: adım 13, 2 resimden 1. Whirlpool Refrigerator Dispenser Solenoid Replacement: adım 13, 2 resimden 2.
    • Remove the dispenser head out of its metal solenoid cube.
  14. Whirlpool Refrigerator Dispenser Solenoid Replacement, Remove the tape: adım 14, 3 resimden 1. Whirlpool Refrigerator Dispenser Solenoid Replacement, Remove the tape: adım 14, 3 resimden 2. Whirlpool Refrigerator Dispenser Solenoid Replacement, Remove the tape: adım 14, 3 resimden 3.
    • Peel the tape off the solenoid connector.
    • Set the tape aside. You'll reuse it during reassembly.
  15. Whirlpool Refrigerator Dispenser Solenoid Replacement, Disconnect the solenoid: adım 15, 3 resimden 1. Whirlpool Refrigerator Dispenser Solenoid Replacement, Disconnect the solenoid: adım 15, 3 resimden 2. Whirlpool Refrigerator Dispenser Solenoid Replacement, Disconnect the solenoid: adım 15, 3 resimden 3.
    • Disconnect the connector attached to the solenoid.
  16. Whirlpool Refrigerator Dispenser Solenoid Replacement, Meter the solenoid: adım 16, 1 resimden 1.
    • If you own a multimeter, you can test your solenoid's resistance.
    • A range between 10-500Ω is acceptable. Check your fridge solenoid specs sheet for more details. The pictured solenoid measured at 33.9Ω.
Sonuç
Repair didn’t go as planned? Ask our Answers community for help.
nicO
15.927 İtibar
89 adet Kılavuz yazıldı
Ekip
Global Fixers Global Fixers üyesi
Community
45 Üyeler
705 adet Kılavuz yazıldı
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 6
Son 30 gün: 34
Her zaman: 898
