Ana içeriğe geç
Whirlpool Refrigerator Door Seal Replacement
Neye ihtiyacın var
  1. Whirlpool Refrigerator Door Seal Replacement, Safety precautions: adım 1, 1 resimden 1.
    • Before you begin your repair, perform the following:
    • Turn off your main water supply
    • Unplug your device
  2. Whirlpool Refrigerator Door Seal Replacement, Open the doors: adım 2, 3 resimden 1. Whirlpool Refrigerator Door Seal Replacement, Open the doors: adım 2, 3 resimden 2. Whirlpool Refrigerator Door Seal Replacement, Open the doors: adım 2, 3 resimden 3.
    • Depending on your repair, open one or both doors.
  3. Whirlpool Refrigerator Door Seal Replacement, Disconnect the door seal: adım 3, 3 resimden 1. Whirlpool Refrigerator Door Seal Replacement, Disconnect the door seal: adım 3, 3 resimden 2. Whirlpool Refrigerator Door Seal Replacement, Disconnect the door seal: adım 3, 3 resimden 3.
    • Insert an opening tool, or a similar tool, between the door frame and the seal.
    • Pry up to separate the seal from its groove on the frame.
    • This may take significant force.
  4. Whirlpool Refrigerator Door Seal Replacement, Remove the door seal: adım 4, 3 resimden 1. Whirlpool Refrigerator Door Seal Replacement, Remove the door seal: adım 4, 3 resimden 2. Whirlpool Refrigerator Door Seal Replacement, Remove the door seal: adım 4, 3 resimden 3.
    • Use your hand and the opening tool to peel the door seal away from the frame.
    • Repeat this process for the perimeter of the door seal until the seal is completely separated.
  5. Whirlpool Refrigerator Door Seal Replacement, Only the door seal remains: adım 5, 3 resimden 1. Whirlpool Refrigerator Door Seal Replacement, Only the door seal remains: adım 5, 3 resimden 2. Whirlpool Refrigerator Door Seal Replacement, Only the door seal remains: adım 5, 3 resimden 3.
    • You're now left with the door seal.
    • During reassembly, perform the following:
    • Use a Jimmy, or a similar tool, to remove any sealing foam in the door frame groove.
    • Use a mild cleaning solution to fully clean the groove.
    • Reinstall your door by attaching the top edge first, then wrapping the seal around the frame's perimeter.
    • You'll hear the gasket lock into the seam.
    • You may have to stretch the seal a few inches at the final edge.
  6. Whirlpool Refrigerator Door Seal Replacement, Perform a seal test: adım 6, 3 resimden 1. Whirlpool Refrigerator Door Seal Replacement, Perform a seal test: adım 6, 3 resimden 2. Whirlpool Refrigerator Door Seal Replacement, Perform a seal test: adım 6, 3 resimden 3.
    • To test if your replacement door seal is working, perform the following:
    • Open the door slightly and insert a clean, flat bill between the door seal and the frame.
    • Close the door and slowly drag the bill away from the device.
    • If the seal is tight, then you should feel a moderate amount of resistance in the bill.
Sonuç
Repair didn’t go as planned? Ask our Answers community for help.
nicO
15.927 İtibar
89 adet Kılavuz yazıldı
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 11
Son 7 gün: 39
Son 30 gün: 172
Her zaman: 3,761
