Ana içeriğe geç
Whirlpool Refrigerator Door Sensor Replacement
Neye ihtiyacın var
  1. Whirlpool Refrigerator Door Sensor Replacement, Open the doors: adım 1, 3 resimden 1. Whirlpool Refrigerator Door Sensor Replacement, Open the doors: adım 1, 3 resimden 2. Whirlpool Refrigerator Door Sensor Replacement, Open the doors: adım 1, 3 resimden 3.
    • Depending on your repair, open one or both doors.
  2. Whirlpool Refrigerator Door Sensor Replacement, Unclip the door sensor: adım 2, 3 resimden 1. Whirlpool Refrigerator Door Sensor Replacement, Unclip the door sensor: adım 2, 3 resimden 2. Whirlpool Refrigerator Door Sensor Replacement, Unclip the door sensor: adım 2, 3 resimden 3.
    • Insert a flathead screwdriver, or a similar tool, between the door sensor and the chassis.
    • Pry up to separate the door sensor enough so you can grip it with your fingers.
  3. Whirlpool Refrigerator Door Sensor Replacement, Remove the door sensor: adım 3, 2 resimden 1. Whirlpool Refrigerator Door Sensor Replacement, Remove the door sensor: adım 3, 2 resimden 2.
    • Pull the door sensor through the chassis enough to access its connectors.
    • Disconnect any connectors attached to the door sensor.
    • Remove the door sensor.
  4. Whirlpool Refrigerator Door Sensor Replacement, Meter the door sensor: adım 4, 2 resimden 1. Whirlpool Refrigerator Door Sensor Replacement, Meter the door sensor: adım 4, 2 resimden 2.
    • If you own a multimeter, you can test your door sensor's resistance.
    • Set the multimeter to the resistance or continuity measurement mode.
    • With the button in its neutral position, the multimeter should read "OL."
    • With the button pressed, the multimeter should read around 0Ω.
Sonuç
Repair didn’t go as planned? Ask our Answers community for help.
nicO
15.945 İtibar
89 adet Kılavuz yazıldı
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 3
Son 7 gün: 25
Son 30 gün: 112
Her zaman: 4,153
