Ana içeriğe geç
Whirlpool Refrigerator Freezer Door Replacement
Neye ihtiyacın var
  1. Whirlpool Refrigerator Freezer Door Replacement, Safety precautions: adım 1, 1 resimden 1.
    • Before you begin your repair, perform the following:
    • Turn off your main water supply
    • Unplug your device
  2. Whirlpool Refrigerator Freezer Door Replacement, Open the doors: adım 2, 3 resimden 1. Whirlpool Refrigerator Freezer Door Replacement, Open the doors: adım 2, 3 resimden 2. Whirlpool Refrigerator Freezer Door Replacement, Open the doors: adım 2, 3 resimden 3.
    • Depending on your repair, open one or both doors.
  3. Whirlpool Refrigerator Freezer Door Replacement, Unfasten the front panel: adım 3, 3 resimden 1. Whirlpool Refrigerator Freezer Door Replacement, Unfasten the front panel: adım 3, 3 resimden 2. Whirlpool Refrigerator Freezer Door Replacement, Unfasten the front panel: adım 3, 3 resimden 3.
    • Remove the screw(s) securing the front panel.
  4. Whirlpool Refrigerator Freezer Door Replacement, Remove the front panel: adım 4, 3 resimden 1. Whirlpool Refrigerator Freezer Door Replacement, Remove the front panel: adım 4, 3 resimden 2. Whirlpool Refrigerator Freezer Door Replacement, Remove the front panel: adım 4, 3 resimden 3.
    • Pull the front panel straight off the chassis and remove it.
    • You may have to slightly open the water filter door to remove the front panel completely.
  5. Whirlpool Refrigerator Freezer Door Replacement, Unfasten the door connections: adım 5, 2 resimden 1. Whirlpool Refrigerator Freezer Door Replacement, Unfasten the door connections: adım 5, 2 resimden 2.
    • Remove the screw(s) securing the freezer door wiring harness.
    • Remove the screw(s) securing the freezer door water hose.
  6. Whirlpool Refrigerator Freezer Door Replacement, Reposition the wiring harness: adım 6, 2 resimden 1. Whirlpool Refrigerator Freezer Door Replacement, Reposition the wiring harness: adım 6, 2 resimden 2.
    • Pull the wiring harness out of its slot in the chassis to access its connectors.
  7. Whirlpool Refrigerator Freezer Door Replacement, Disconnect the wiring harness: adım 7, 3 resimden 1. Whirlpool Refrigerator Freezer Door Replacement, Disconnect the wiring harness: adım 7, 3 resimden 2. Whirlpool Refrigerator Freezer Door Replacement, Disconnect the wiring harness: adım 7, 3 resimden 3.
    • Disconnect any connectors attached to the door wiring harness.
  8. Whirlpool Refrigerator Freezer Door Replacement: adım 8, 1 resimden 1.
    • Place a clean cloth under the water hose before continuing.
  9. Whirlpool Refrigerator Freezer Door Replacement: adım 9, 2 resimden 1. Whirlpool Refrigerator Freezer Door Replacement: adım 9, 2 resimden 2.
    • Pull the plastic clip off the freezer door water hose.
  10. Whirlpool Refrigerator Freezer Door Replacement, Disconnect the water hose: adım 10, 3 resimden 1. Whirlpool Refrigerator Freezer Door Replacement, Disconnect the water hose: adım 10, 3 resimden 2. Whirlpool Refrigerator Freezer Door Replacement, Disconnect the water hose: adım 10, 3 resimden 3.
    • Use one hand to compress the blue plastic ring into the green section of the hose.
    • Use the other hand to pull the water tube out of its slot.
  11. Whirlpool Refrigerator Freezer Door Replacement, Unfasten the freezer door: adım 11, 2 resimden 1. Whirlpool Refrigerator Freezer Door Replacement, Unfasten the freezer door: adım 11, 2 resimden 2.
    • Depending on your device, you may have a plastic cover on the hinge. Remove it before continuing.
    • Hold the door while performing the next two steps to avoid the door from accidentally falling.
    • Remove the screw(s) securing the freezer door.
    • Some devices may have screws solely for alignment. You don't need to remove these.
  12. Whirlpool Refrigerator Freezer Door Replacement, Remove the door hinge: adım 12, 3 resimden 1. Whirlpool Refrigerator Freezer Door Replacement, Remove the door hinge: adım 12, 3 resimden 2. Whirlpool Refrigerator Freezer Door Replacement, Remove the door hinge: adım 12, 3 resimden 3.
    • Pull the door hinge straight up to separate its alignment pins from the chassis.
    • Remove the door hinge.
  13. Whirlpool Refrigerator Freezer Door Replacement, Reposition the cables: adım 13, 3 resimden 1. Whirlpool Refrigerator Freezer Door Replacement, Reposition the cables: adım 13, 3 resimden 2. Whirlpool Refrigerator Freezer Door Replacement, Reposition the cables: adım 13, 3 resimden 3.
    • Pull the freezer door straight up to disconnect it from the chassis.
    • Thread the cables through their slot in the chassis.
    • You may need to thread them individually.
  14. Whirlpool Refrigerator Freezer Door Replacement, Remove the door: adım 14, 2 resimden 1. Whirlpool Refrigerator Freezer Door Replacement, Remove the door: adım 14, 2 resimden 2.
    • You're now left with the freezer door.
Sonuç
Repair didn’t go as planned? Ask our Answers community for help.
nicO
15.927 İtibar
89 adet Kılavuz yazıldı
1Rehber Yorum
There is a pending class action suit about this defect: https://chimicles.com/whirlpool-refriger...
Barbara Hoover - Yanıt
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 2
Son 7 gün: 13
Son 30 gün: 41
Her zaman: 2,039
